Question about RTO PasLode 900420 Impulse Framing Nailer
Brand new gun won't work right.
This is the second Cordless Framer that I have bought that does the same thing. Won't shoot more than about 2 nails before the drive pin won't reset all the way back up to let the next nail advance to be fired. Brand new out of the box from Lowe's this last one I bought had this problem. First one worked ok for a little while before it started doing it I had Lowe's send it off for repair and it came back doing same as when it was sent off. Then they wanted to cahrge me $59.00 for repair. I said bull on that and argued with them that it was only eight months old and I'd only used it three times briefly before it started messing up. I said it should have been repaired under warranty and they gave me a line about cleaning and replacing normal wear items wasn't covered under warranty. I told them as new as it was and no more than I had used it it wasn't any wear parts to need replacing and as far as it not being clean it was practically still brand new. They finally agreed not to charge me the $59.00 this time. I'm not sure about these guns being worth what they cost or being as good as they're supposed to be now that I've owned these two. I'm getting ready to take one of them back to Lowe's for a refund and the other to my local service center and actually show them what it's doing before they work on it. I have a 40'x60' picnic pavilion to build for my church and it would have really been nice to have one of these guns working to be able to use but mine will be in the repair shop unfortunatley while I'm building the pavilion.
  • yadayada
    yadayada May 11, 2010
    buy an air powered gun and buy a good brand like Dewalt
  • 10,865 Answers
I share your frustration with these paslode framers. Since you are working clost to electrical power I recommend a regular pneumatic framer and a compressor. Cheaper to buy, cheaper to use and must less trouble overall. Best of luck to you as u do God's work.
Posted on Jul 28, 2009
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
I just bought a porter cable fr350a nail gun and need to know what type and angle nail goes in it.
it will shoot a nail from .113 to .148 diameter plastic collated full round head from 2" to 3 1/2" 22degree nail. If you want you can download the instruction manual from Dewaltservicenet.com and type in your model number under looking for manual it is 15 pages long. If I have helped you with your request would you please rate this response accordingly and thank you.
Nov 12, 2009 | Porter Cable Cable No. FR350A Rnd Head...
2 nails shooting at once from nail gun
Could be couple problems. Are you using the right nails for this tool the right guage and degree? Is the nose worn allowing 2 nails to be able to shoot. Give me the model number and brand and I will try and find a print for this tool with firther suggestions, but these would be the most common
Sep 27, 2009 | Campbell Hausfeld Tools & Hardware -...
How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
May 31, 2009 | Stanley Bostitch F21PL Nailer
Need to know the brand of nails that work with this nailer
brand does'nt matter its the lenght and more inportant is the gauge if its shooting two nails than you are most likely using the wrong gauge example of gauges:16mm 18 mm ect. look on gun it should specify which gauge to use
Apr 30, 2009 | Tools & Hardware - Others
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Jan 25, 2009 | Porter Cable Cable No. FC350A Clipped Head...
RTO PasLode 900420 Impulse Framing Nailer  Logo
301 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
