Question about Canon Rebel XT / EOS 350D Digital Camera
Memory card is not formatting . message appears and when I try to format it, it is not working.
  • maddmike71 May 11, 2010
    What is tthe message it displays?
    Genius:
  • 1,234 Answers
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
    SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
    Formatting a memory card
    ** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
    images, including the protected images, will be deleted. Be sure to download important
    images to your PC before formatting the memory card.
    ** If the memory card is not inserted, the internal memory will be formatted.
    ** Be sure to format the memory card if you are using a newly purchased or non-initialized
    memory card, if it contains data that the camera cannot recognize, or if it contains images
    captured with a different camera.
    Formatting a Memory Card
    1. In any mode other than Voice Recording mode, press the MENU button.
    2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
    3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
    4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
    - If [No] is selected : The memory card will not be formatted.
    - If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
    Apr 12, 2010 | Samsung Digimax 401 Digital Camera
    My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
    Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
    [No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
    [Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
    Be sure to run [Format] on the following types of memory card.
    - A new memory card, or an unformatted memory card
    - A memory card that has a file this camera can't recognize or one that has been taken from another camera.
    - Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
    Apr 12, 2010 | Samsung S630 Digital Camera
    Sandisk micro sd card forget password in nokia
    Try putting the memory card in your PC and formatting it from My Computer.
    If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
    Jan 26, 2010 | SanDisk 2GB microSD Memory Card
    A 2gb memory card says memory full tried it in
    No, that camera works with the 2gb cards just fine. You will want to try to format the card in your computer first, then try it in your camera (format it in the camera before using). If it doesn't format in the computer, it is a bad card.
    Jul 19, 2009 | Kodak EasyShare C330 Digital Camera
    Memory card problem
    Promblem Regarding Memory Card of 6600 Nokia. ------------------------------------- 1). Format the memory card by the phone using "format" option available in memory card "options".
    2). If still same problem appears, then format it through pc-suite software, or through memory card reader which available in market (this process is by using PC).
    3). If still same problem appears, then try with a new memory card.
    Because it depends on your handset. After inserting a new memory card, if the same problem appears please contact your nearest "NOKIA CARE".
    All the Best....
    Thanking you.
    Mar 02, 2009 | Nokia 6600
    When i try to ytyake a picture an error message appears memory card error
    Is that exact what it says? I need more information. What kind of camera is it? I'll try to help with the little information I have:
    I think your memory card is full and needs to be formatted. Select 'Menu' and look for the 'Format' option and select it. Before you select 'Yes' make sure you save any pictures that you might want to keep onto your computer. Because once the memory card is formatted you won't be able retrieve the pictures. It should ask you before formatting your memory card. While it's formatting make sure to keep the camera steady (if it's an older camera the slightest bump could disrupt the formatting process). This should take no more that a minute or two. When it's complete your memory card will be completely wiped clean. You'll now be able to take pictures. If the message appears again repeat the same process.
    Note: When you 'Delete' a picture it doesn't completely leave your memory card. It will continue to take up space until you format your card.
    I suggest formatting your memory card often (or you might miss out on a perfect photo opportunity and have to delete pictures you haven't put on your computer yet).
    I hope this helped,
    Owen
    Sep 22, 2008 | Cameras
    AIPTEK IS-DV2
    First check the memory card to see if the lock tab is in the UNLOCK position. On the top left of the memory card is a slide the moves up and down. The slide should be in the up position for it to be unlocked. A locked memory card could cause the camera to read a CARD PROTECT error message.
    If you still receive an error message, verify that you are inserting the card correctly so that the spring locks in as you fully insert it. When performed correctly an Icon will appear in the lower right hand corner of the LCD screen. Also try inserting the card while the camera is on.
    The memory card may also need to be formatted through the camera’s settings-- Note: Formatting will delete all files, so be sure to transfer any important files to your computer before doing so
    To Format: Insert the memory card into the camera and press the mode button to get to the mode screen. Enter into Tools/SETTINGS and find FORMAT. Once you select format you will receive a YES or NO option. Select YES and you will see a FORMATTING message. Once the formatting is complete, see if the camera reads the card and functions properly
    Jul 08, 2008 | Aiptek IS-DV2 Camcorder
    Problems with formating samsung e250 micro sd card
    I had the same problem and I tried everything. I couldn't think of anything else to do so I just turned my phone off and back on again. When I went back to the memory card menu on my phone all the folders that I lost re-appeared. I don't know if it would work on other phones but it's worth a try!
    Mar 11, 2008 | Cell Phones
    Formatting Memory Card
    did you format your card? try going into the set-up menu on your camera and you should find a format option - THIS WILL ERASE ANYTHING YOU MAY HAVE HAD ON THE CARD...so if you have anything on there use a memory card reader and transfer it to your computer before formatting. If the formatting doesn't fix the card error message you could try formatting it on your computer (if you have a pc, go to 'my computer' and under 'removable devices' you should see the memory card, right click and choose format - i don't know the process for macs, but i would guess do a ctrl+click on the memory card when it appears on the desktop). If that still doesn't work the card is probably corrupt and you may need a new one.
    Feb 01, 2008 | Samsung Digimax 4010 Digital Camera
    Canon Rebel XT / EOS 350D Digital Camera Logo
    43 people viewed this question
    Top Canon Cameras Experts
    TC CAMERA REPAIR.Com...
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
