I need to get my tv back on channel 75 but it skips from 71 up to 99. How do I channel search?
  • k_clevinger Jul 28, 2009
    It's a 1993 Magnovox RS1962 B421. I don't know how to do a complete channel search. I think that's what I need.
  • Greg Woods May 11, 2010
    What type of TV.? How old.? Have you tried a complete channel search?
  • 4 Answers
I have a Sylvania TV. However, the solution should be roughly the same. There are several reasons for your issue. The TV provider could have moved the channel or taken it off of its roster. Or the cannel could have been deleted from your TV set-up by mistake. Barring that, you could do either a manual or automated channel scan. Make sure to save the channels.
Posted on Jul 29, 2009
How to reset my westinghouse flat screen tv
if you are using an antenna for digital channels,it will search for 100 to 125 channels,if searching for the old analog channels,it only searches for 75 channels,but,you will not receive them,they are gone now,if you have a cable box,then you only need channel 3 or 4,
May 18, 2015 | Westinghouse SK-32H540S 32 in. LCD TV
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
Oct 18, 2014 | Sanyo DP19649 LCD TV
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
Can't get certain channels to come in even when I do a channel search
Check whether those channels have been skipped. If skipped, get tem back. Refer its user manual for details.
Jan 24, 2013 | Apex Digital LD3249 LCD TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Ch setup on a vizio tv.
( FOR VIZIO TV MODEL VO47L )
Press menu on the remote,
then go to the icon that says TV,
then press down on the remote to change,
"Tuner Mode" for Cable or Antenna.
"Auto Search" for auto search channels
"Skip Channels" for removing the unwanted channels.
If you need a copy of your manual, go here:
http://www.vizio.com/downloads.aspx
May 23, 2009 | Vizio VO47L 47 in. LCD TV
New ariel installed on communal roof, have tried auto store, some channels now missing, samsung 23" LCD TV LE23R8
 you must run "auto program search"/"auto store" again and let the TV find the programs. then put them in order and store.
If you feel some channels are missing, try to find them manually. The auto store function sometimes skips programmes with less tolerant range, even if they are watchable in a fairly good quality. And search slowly and pay attention and go back if you feel you just skipped something. Good luck and lots of patience!
A new aerial sometimes might mean loss of some channels.
I hope it was helpful
Apr 17, 2009 | Samsung Televison & Video
Channel search: skips chanels
If you have a cable box connected, it's synch circuits are bad. If your TV has a selection for HRC/ IRC make sure you know which one cable company is using .
Apr 15, 2017 | Polaroid FLM-1911 19 in. LCD Television
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
More channels
Go into the menu to the "Search" tab, channel down until you are on "auto search" then press "volume up"
this will automatically add channels you can get, you can manually change skip settings there too if you want to not see a channel you get or for some reason add a channel you don't get etc.
Mar 01, 2008 | Insignia IS 20" TV040919 TV
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
