Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
Kitchaid Superba KSRG25 not cooling freezer or refrigerator. Sounds like the fan is running but nothing else.
  • 27 Answers
Either stuck in defrost or compressor failure or loss of gas
Posted on Jul 29, 2009
  • vnytes
    vnytes Oct 11, 2012
    How do you know which one it would be
My refrigerator isn't cooling well. The freezer isn't freezing at the top only the bottom.
if it's just cold at the bottom and warm up top it sounds like you have a bad evaporator fan motor in the freezer side,when you open the freezer door do you hear the fan blowing?if not bad fan motor,this happens when the fan motor is bad because heat rises and cold air sinks.part number : 2259385 and it's around 60 to 70 dollars
Nov 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
Hello...our superba freezer is not working...the frig. side (right) is also not working now...we hear the fan inside the freezer but nothing else. What's wrong w/ it?? Thanks.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | KitchenAid Superba Architect KSCS25INSS...
Freezer is working fine but refridgeater is not working. Side by side kitchaid
Probably the 'Chinese fan syndrome.'
The freezer compartment is (logically) favored for cooling. There is a fan, normally between the back of the freezer compartment and the outside sheet metal that circulates the cooled air from the hidden coils to the refrigerator compartment.
Try this: When you hear the compressor is running, look for vents in the back of the refrigerator side and hold some wet fingers in front of these. Under normal circumstances, there should be an easily noticeable flow of air coming from these vents that represents the fridge's share of the cooled air. If there is none or is very little flow, the fan has either slowed (sticky sleeve bearings) or the fan has stopped completely.
This isn't a dangerous problem since all modern electric motors are 'impedance protected' meaning that if the motor cannot turn, it still will not get any more than hot, it won't catch fire as they once would.
Sears carries or will order a vast number of parts for appliances other than Kenmore and has thousands of illustrated breakdowns of these in their library.
Use the link below to go to their parts department and enter your model number to see if they have your KitchenAid model in their library. If they do, you will have a line drawing illustration of your appliance which you can use to see how to access and replace the fan yourself.
Sears parts
If it appears too difficult for DIY, you may be able to at least order the part to avoid the markup of the service company that comes to swap the fans out.
Apr 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ksrg25 kitchenaid is running, cooling, freezing but making a clicking noise at compressor every couple of minutes or so?
there ia probably a mouse knawing a the rear entry conductor, it's warm and does have a slight vibration... be very quite and listen...
Mar 24, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Freezer is not cooling. Fan not running
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
56fhzfjhhgk
Dec 14, 2009 | KitchenAid Superba KSRG25FK Side by Side...
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer works fine, fridge is not cooling. Side by Side KitchenAid Superba - KSRS25C
sounds like fridge fan is out,sometimes they stick and do not send cold air to otherside,replace or repair.
Apr 24, 2009 | Refrigerators
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
679 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
