Question about Niko OTP-3211W 32 in. LCD Television
I NEED A POWER CORD
CAN YOU TELL ME WHERE CAN I FIND APOWER CORD FOR THE TV
  • yadayada
    yadayada May 11, 2010
    a tv repair shop.
It uses the same power cord as a computer uses. You should be able to find one at any computer store. I am talking about the cord that plugs in to the power supply on a standard tower ibm style PC.
Posted on May 09, 2010
This TV uses a standard power cable that is also used in many other TVs, monitors, and computers. It is a CEE 7-7, which is often called a 'PC power cable' or 'standard 3 prong power cable'.
You should be able to find them almost everywhere, but your local Radio Shack, Bestbuy, or Walmart are all sure to have them.
Posted on Sep 16, 2009
  • Tephlon Sep 16, 2009
    Clarification:
    Sorry. The end that plug's into the TV is actually called a IEC C13, or 'PC Flex'... but in any case, the rest of my comment still stands. The CEE- 7-7 is actually the end that plugs into the wall, which can vary depending on your country (the CEE 7-7 is a European wall socket standard)
Where can I get a power cord
Alternatively referred to as a power cable, mains cable or flex, apower cord is the primary cable that provides power to the computer, printer, monitor, and components within a computer. In the image to the right, is an example of the power cord that is commonly used with computers, monitors, printers, and otherperipherals.
Mar 25, 2016 | Office Equipment & Supplies
I need a power cord for model number ELCHS321
go to www.shopjimmy.com. The power cord you probably need is a 3 prong right angle cord. Check the back of the TV to confirm the pattern of the cord.
Aug 24, 2014 | Element ELC-HS321 32 in. LCD TV
Need a power cord Where can we purchase one?
The best place to start would be the place you purchased your T.V. from, but if that is not available I would suggest using Amazon.com (searched tv power cords, but you can put in your specific T.V. to narrow the results).
If you prefer to visit a physical location, then Best Buy would likely carry any power cord you would need. Just tell them your T.V.'s make and model and they should find what you need.
Jul 28, 2011 | Televison & Video
I have a sanyo 26 " lcd hdtv and we had apower
hi you will need first to isolate where the problem might be so try to plug other unit or device in your power surge like a dvd player. if it is work your lcd tv have problem now how are you going to fix your tv, use a philip screw driver and open the back cover to gain access the internal part. since doesn't turn on check the power supply first which is the main source of supply of all the board. replace blown fuse and other defective part. bulged capacitor will not work good replace it use the panasonic brand atleast 105c ratings it is effective. thanks hope will help you to fix the problem.
Jun 19, 2011 | Sanyo Televison & Video
THERE WAS APOWER PROBLEM AND MY MICROWAVE COMPLETELY STOPPED WORKING.NO DISPLAY AND NO SIGN OF AN OUTPUT
Check the main fuse inside the oven on the floor of the cabinet near where the power cord enters.
I believe you will find it needs replacement.
May 27, 2011 | LG Microwave Ovens
My boyfriend's tv won't turn on.. He says when he tries to, the tv's red light just keeps flashing at him. Have any idea whats wrong with it?
Sounds like a power supply failure... probably caused by bad capacitors on the power supply board.
the power supply board can in some cases be repaired, but in other cases will need replacement.
Apower supply repair is likely to cost around £80 and a new board can be between £80- £200 depending on make model.
Sep 01, 2010 | Televison & Video
Ihave a sony KP53S75 TV there was apower surge and now there is no picture. The red light blinks 4 times can anyone tell me about this?
Hi, if this TV was hit by the surge and it was protected by a surge protector, please follow this reset procedure.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the problem is still there and the light is still blinking 4 times, this means that the surge has destroyed the Vertical deflection component. in this case, it will have to be replaced.
please rate and have a great day.
Mar 25, 2009 | Sony KP-53S75 53" Rear Projection...
I need apower cord for flat screen model# p701 name sl70011ms
usually the power cords are very standard... the power cord communly used has the 3 prongs and has a d shape female/male plugs... try the thrift store.. (I found one that i needed like that.. i had to unplugg it from an old monitor because I did not want to get the monitor so I paid like 2 bucks instead of 10... or just go to a computer store... they may have spares they can sell to you for cheap.
Sep 21, 2008 | Computers & Internet
Laptop
Try removing the battery pack and then power up with the cord. If it works, then it means that the battery pack needs replacing/recharging.
If it still dos not work, the cable could be faulty. Get it replaced.
May 15, 2008 | HP Compaq Presario C304NR Notebook
Niko OTP-3211W 32 in. LCD Television Logo
115 people viewed this question
Top Niko Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Andrew Taylor
Andrew Taylor
Are you a Niko Televison and Video Expert? Answer questions, earn points and help others
