Question about Samsung CLP 300 Laser Printer
Printing jammed on thicker paper
Hi i have a samsung clp300 laser printer
im trying to print some engagement invites so the paper is of the thicker texture (as you would with cards) but when i load it in the tray the printer keeps jamming up. does this mean i can only print with normal paper and not thicker textured ones??? is there any way i can change the settings or the paper tray so it can print?
chi
  • 1 more comment
  • Anonymous Dec 04, 2007
    I have just purchased and installed this printer, and can't get it sheet feed at all - whether I use plain paper or not. It sends out one blank sheet and then tells me there is a paper jam. I have checked for tips in the manual, I know how to set it for different weights of paper etc, and I have also been careful to fan the paper and not put in too much or too little.
  • signandprint Dec 15, 2008
    My printer is a year old was brillaint when first bought for printing all papers and envelopes, it got gradually worse and can now only print thin paper, why?
  • Anonymous Mar 26, 2014
    i printed a paper but it became paper jam process.but i managed to take the paper out.but now the printer is not printing.what to do?
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Posted on Dec 03, 2007
I adjusted my printer setting to "Thick Paper" as that worked for me.. I sounds like the printer feeders are working a little bit harder than before , and the printer makes a little beep faint beep sound ,but I dont get any paper jams anymore .. I using 80g/m2 paper.Since then I have printer over 200 pages without jamming..
Hope this will help
Posted on May 17, 2009
I cannot print heavy paper. It consistenly jams. My HP inkjet prints the same weight of paper easily. Suggestions?
The maximum paper weight that should be used on the CLX-3175 is 163gsm, so if you use thicker paper it would jam.
Jun 04, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Hello, I was printing a 30 page document on my samsung CLP300 printer and it quit printing after 20 pages. It does not indicate that it has a low ink cart. and I see no signs of a paper stuck anywhere (I...
There are many reasons that causes this printer to stop printing, like empty toner cart, full waste toner cart, paper jam. The only way to know for sure is to use the smart panel program to see what the printer is sensing as a problem and go from there. Hope this helps.
Oct 07, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP300 jams when normally printing, but will print test
If you are using a 6cm paper to print that is smaller than a A4 size paper.
do a check when you print did you select the correct paper size. as wrong paper size is print will course paper jam too.
Apr 08, 2010 | Samsung CLP 300 Laser Printer
Jamming when Print heavy paper on Samsung 510
printer only handles up to 120gsm,any thicker will jam.
Jul 11, 2009 | Samsung CLP-510 Laser Printer
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Samsung printer CLP300
Clean the rubber feeder belt with alcohol. Worked for me, Yesss!!!
Nov 03, 2008 | Samsung CLP-300N Laser Printer
Clp300 paper jamming
Section one is usually the bypass ( the front tray that you have to open the door)
it is trying to print from there
otherwise clean the tires in the tray area with alcohol, they probably contain dust and the paper is slipping.
Aug 07, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
571 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
