Question about Star Manufacturing International Tractor with Trailer 6V Ride-On - Yellow
Tractor has been sitting for awhile,transmission
Tractor has been sitting for awhile, was running fine last year when parked , charged the battery , engine turned over just for a second and stopped , connected jumper cables but no change.Transmission is out of gear, motor will not turn over and I can't get the tractor to move even when trying to pull it with my truck with the clutch pushed in. It acts like it is locked in gear ....any ideas?????
  • ldees1352 Jul 30, 2009
    Thanks for your quick response and much to my sorrow you are correct. I pulled the head off today and motor is frozen.
    Thank you so much
    Larry
  • 850 Answers
Old oil in motor & may be too level too low aswell
condensation or moisture has probably got to the cylinder bores & bearings etc!
my guess would be it has locked up !
try lubricting the cylinders & rocking the cranckshaft as this can sometimes free them up
but i doubt if it will be in any condition to use even if you get it freed up & maybe even started again!!
best bet would be to strip it down & recondition it!
Cheers Rob
Posted on Jul 29, 2009
  • ROB Jul 30, 2009
    sorry im correct m8 lol
    good luck with it
    cheers Rob
Craftman 18 hp won't start with key
Check Battery. If headlight equipped turn key to headlight on position and see if headlights are lit. No light dead battery dead tractor,
Charge battery. If after charging weak or no start forget the battery and get new, Life of battery is two to three years,
If battery good make sure that parking brake set and blades are not engaged. Safety lockout will prevent tractor from cranking. The tracker has a safety interlock on the seat that requires a body warm or cold sitting on the seat if the parking brake is not set. The seat switch is known to fail. Try bouncing on the seat?
OK if battery OK and seat is sat or park brake set we can assume the safety interlock circuit is disabling the start circuit.
Need model to provide more answers
This website video shows how to check the component. Your model would be similar.
How to test lawn mower electrical safety switches
This electrical diagram is for a typical lawn tractor. Your model would be similar but different . This will give you an idea. The switch on the seat has two sets of contacts.26045611-oxnapdkevdwqbvzn03d44ye1-1-0.png
Jan 09, 2016 | Garden
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
Simplicity zero turn electrical problems
charge the battery not hooked up to the mower let it sit overnight and try again the battery might just be died they only last a couple years put a volt meter on the battery when off then start it and watch the battery voltage should be around 14 volts running the pto clutch draws the most thats why it shuts off first the ign doesn't take any the carb needs very little
Apr 22, 2012 | Garden
I have a 2004 Honda Siverwing. It has been sitting for 2 years. Can the battery be charged or do I have to buy a new one
You can try charging the battery. It will not hurt anything to try. Batteries generally only last two years or so. It may charge and be okay for awhile or it may charge and not hold the charge for more than a day or two. It may simply not take a charge. I would get a new battery just for the peace of mind. Please rate my answer. Thanks.
Aug 12, 2010 | Honda Silverwing 600 Motorcycles
17.5 hp 42" deck Sears tractor. Parked it in the shed after last mowing, everything was fine. Went to mow yesterday and tractor will not drive plus I have no brake....what happened? Belts are fine, gear...
If the engine is running normally and your drive belt is fine then the input to the transmission is OK you just have no power output from the transmission. Usually those transmissions give you some signs of failure such as won't go up inclines or the top speed is a bit low. What I would do is first check the linkage from the forward/reverse lever to make sure it is moving a corresponding shaft on the transmission itself. If that is good then I would check the fluid level on the transmission itself. This could well require removing it from the tractor. Often the brake pedal is connected to a small disc on the transmission. While you are checking the shifter input to the transmission, you may want to follow the brake pedal rod back and see if anything is broken or disconnected.
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Intermittent poor acceleration, loss of power. Has
How is your charging system? Sounds to me like it's not charging your battery, so it runs until the battery cannot support the ignition load.
Apr 24, 2017 | 1992 Buick Park Avenue
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
My tractor cuts out and dies, then with a recharge, it runs.
Not likely, if the battery is any good you should get several hours of run time before it dies. More likely low oil pressure cut off switch, check level or change oil if it's been awile. Or possibly an overheat cuttoff swith, check airlow and coolant if it has a radiator.
May 10, 2009 | Garden
Star Manufacturing International Tractor with Trailer 6V Ride-On - Yellow Logo
132 people viewed this question
Top Star Manufacturing International Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Star Manufacturing International Toy Expert? Answer questions, earn points and help others
