Question about Tools & Hardware - Others
Dw331k jigsaw is stuck on slow ..the switch on side moves to all setting and the speed ajust turns around as well but nothing happening
SOURCE: Not able to change flash setting - button not working
This worked for me. Thanks.
Posted on May 29, 2007
  • 4 Answers
SOURCE: can not ajust monitor icons are huge will not
your display adapter is not installed, try to install it using your mortherboard installer....
Posted on Jun 18, 2009
protek480
  • 1723 Answers
SOURCE: will not cut straight lines
Tension the blade so it's correct tension.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
  • 177 Answers
SOURCE: Stuck in slow (turle) setting.
Hi. This fault could have a few different causes.
Does your hand control have a dial for the turtle to rabbit speed control, or does it have an up button and a down button?. I have had a few dial ( potentiometer ) pots play up, and cause similar problems.
The fault could also be faulty Battery or Motor connector. These terminals develope a bad connection and can get that bad that the plastic housing starts to melt with heat. Also check battery terminals are tight.
Do the batteries last? I have had a few machines with a burnt out motor.These often still drive but only slowly, and the batteries fade quickly.
Good luck. Neil.
Posted on Jun 04, 2010
junk9
  • 150 Answers
SOURCE: smoke comes from around the switch when turned on
If it is under warranty, take it back. If not then it is a simple matter of replacing the switch. Take off the cover and pull out the switch. Mark each wire as you take it off. Take the switch with you to the store. First try a hardware store, then an auto parts store. If they don't have it try Sears. They will probably be able order it. Make sure you have the model number of your grinder. It is on a data plate somewhere on the grinder. If Sears can't get it, try a wholesale electrical parts house.
Posted on Nov 19, 2010
How can I fix the speed myself on a Steepletone ST918 record player ? 33rpm plays LP's at 45rpm !!!!
I am not familiar with this brand, but many turn tables adjust the speed using a rubber wheel and a turntable motor with different shaft sizes. The shaft is ground smaller in steps the further from the motor. As the rubber wheel is moved up the shaft, the slower the turn table spins. Most times you can lift the turntable up (may have a clip to hold it in place) and look to see if the wheel moves up and down on the shaft as you shift speeds.
Jul 18, 2014 | Wurlitzer Jukebox 1015 One More Time...
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.
Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.
Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."
Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.
Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.
Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
As I slow down or stop at a stop sign or red light it turns off. It drives good in a highway, as soon as I get out of the highway it turns off, or as I'm driving in the city. Took it to the mechanic can't...
Does it happen in stop and go traffic? If the answer is no and the only time it does happen is at speeds at about 40 mph's or better then its the brake switch its failing to cancell out Torque converter clutch solenoid (TCC). If it happens at all speeds take the vehicle to a shop that does SCOPE TESTING NOT A SCANNER this way they can hook the vehicle up to the SCOPEMETER and drive around with it to see what turns off (other than the vehicle) and causes the vehicle to die.
Apr 09, 2010 | 1998 Oldsmobile Silhouette
Tools & Hardware - Others Logo
113 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
