Question about Toshiba 36A50 36" TV
Two white lines on the screen - no picture. is the tube blown?
  • 28 Answers
I dont think so
how the lines are?
horizontal or vertical?
Posted on Jul 29, 2009
3 Suggested Answers
  • 6771 Answers
SOURCE: I have a RCA colortrak 2000 picture tube TV .
You have a vertical problem, caused by vertical deflections circuit failure, can involve a number of parts to fix.
Posted on Jan 03, 2011
salt56
  • 373 Answers
SOURCE: I HAVE A HALF SCREEN.
This is commonly known as a vertical deflection problem. It cannot be fixed with an adjustment, but requires changing some electronic components. Namely the vertical output IC (integrated circuit) and in addition usually in this model a resistor which may appear to be burned.
Posted on Jun 16, 2011
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
Tip
White Raster with thin lines; Sound Ok.
White raster with retrace lines: No picture, Sound OK
(picture tube based telivisions.)
It is a common fault to occur in most of the CRT based telvisions, regardless of which brand it is. There will be sound OK, and a bright screen with thin white horizontal lines across; at about an inch space, all over the screen area. This fault may occur along with colur shades also, like blue screen with white retrace line, red screen with white retrace lines, green screen with white retrace lines. Let us take the first case. A white raster with white thin retrace line acorss the screen. These are call vertcial retrace lines technically. To make it mor understand, we have to go to some picture tube electrode details. There are three colour cathodes for a colour picture tube, Red, Blue and Green. Two girds are there called Focus and Screen. Focus grid is supplied with focus voltage which in turn determine the cocus of picture, and screen grid is supplied with screen volrage which determine the emission of the picture tube; in short. There is a final anode to all the picture tubes, which supplied with Extra High Tension voltage, can be located at the top side of the picture tube, to which the EHT voltage from LOT is connected with the help of rubber ****** and clip. Without these three voltages, EHT, Screen and Fcous, no raster will be produced. Therefore in our case, there is a raster, so, horizontal output section including Line Output Transformer [LOT] is functioning well, and as far as sound is there, tuner and video IF section are working well. In fact, all other section except, video output section is working properly.
There are three cathode points on the base card, marked as Bk, Rk and Gk. Check the voltages of these three cathodes. In our case, it will be very low or approximately equal to zero. When cathode voltages goes low, emission of the CRT increases, is the reason. There must be a voltage between 120 and 135VDC at these points. Find out the reason for this voltage drop is the next step. The video drive voltages in most TVs comes from LOT windings, after rectification and filtering. There will be one reisitor of low value, say one Ohms or so, will be connected series with this winding, in between diode and winding. Check the voltage at the cathode of this rectifier diode first. If found low replace the diode and the smoothin capcitor. The smoothing capacitor will be between 33 and 47MFD 250VDC rating. Replace both of them. If there is volatge, say 200VDC or so, check whether this voltage comes to the CRT base board or not, If not, check the conducting wire, serial resistors; if used for open. There is no chance of transistor shortage at this time as the raster we see is white. If raser we see have a specific colour predominent, that is green, blue or red, check the revalent video out transistors and replace it. It is best to replace all the three video output transisors at the same time with same batch and number.
on Apr 18, 2011 | Televison & Video
I have a white line running down the centre of my tv screen. It is a jvc and dvd combo. the dvd player is on the side of the screen
If you are having a white line in the middle of the screen and sound it an indication that you have blown the vertical deflection amplifier. Don not switch on the TV till you get it fixed as you can damage the picture tube in the central area permanently.
It is a 11 lead IC mounted on an a aluminum heat sink. Will cost you about less than 10$ plus labor to replace.
Jul 15, 2011 | JVC AV-32020 32" TV
When ever there is some strong white on the screen it gets distored. For example. There was a white tent on screen and where the light was hitting it it was extremely pixelated and distorted. Ny ideas?
Hello
This fault can occur to mainly three reasons. ABL circuit failure. Low screen voltage or lack of emission from picture tube cathode. Just advance the screen voltage to a little, and observe the result. Screen control can be located on its Line Output Transformer [LOT]. there will be two variable controls built on to LOT marked as screen and focus. Screen control will be at lower side, and focus will bw on the top. Just advance [clockwise movemnt] to a little, not more, advance it till retrace lines are just visible on the screen. Before doing this, set all the picture controls, contrast, colour and brightness of the TV to zero. Once the retrace lines[thin horozontal white lines across the entire screen at about 1 inch distance with each other]; are visible, stop there, turn the screen control counterclockwise to just a point when these lines are just goes off. make this adjustment in a dark room so that you can set this point very correct. After this check the perfomance of the picture. If this does not help you, ABL circuit should be checked for any fault.
If emission of the picture tube has got down, even the screen adjustment said above won't help you. The only way is to replace the picture tube with same type and number. OK.
Apr 16, 2011 | Sanyo DS24424 24" TV
White lines on the screen.sounds ok.picture is coming behind white line.
Lines means Screen Drive is overdriving, try adjusting the Screen control on the FBT flyback Transfomer, adjust it down. If that does not Clear out Problem then replace the CRT Board that is connected to Picture Tube.
Jan 22, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
Aug 03, 2010 | Sansui Televison & Video
Ps3 has black screen with white lines some noises
I am sorry but the voltage surge, which must have occured after having switched off the protector has most probably blown or fried the High Voltage circuitry which makes the tube function. It could be that both horizontal & vertical control IC's are damaged. If the picture tube is still OK then its worth repairing. However if the picture tube is gone then better to buy a new diplay unit after checking up the rest of the equipment that a playstation consists off......................................sodeep
Aug 09, 2009 | Sony Video Game Consoles & Games
GREEN VERTICAL LINES
vertical line ic no pda 3653
Aug 16, 2008 | RCA F36650 36" TV
I have a 1985 Zenith Space Command Color TV. It has developed thin white lines at the top of the viewing screen. The rest of the screen is clear. Is it something small or am I looking at a new picture...
The picture tube is fine.
Those whites lines at the top of the screen are caused by a dry or leaky capacitor(s) nearby the vertical amplifier IC.
Let me know if you require further assistance.
Jul 26, 2008 | Televison & Video
Toshiba 36A50 36" TV Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
