Question about Foxconn 661FX7MF-S Motherboard
Mobo won't accept P4 CPU.
I have a Packard Bell GA-8SIMLNF motherboard which boots up with a Celeron D CPU. I would like to use a P4 3GHz CPU but it only starts up for about 5 seconds then turns off with this CPU installed. The specs say it can use a much higher CPU than 3 GHz so I am thinking that the BIOS needs updating to accept anything other than a Celeron CPU, or there is a BIOS setting to change the CPU type.
Can anyone help?
Thanks.
  • 433 Answers
There are FSB settings as well as voltage settings in your bios. Go to intel website to get correct voltage and FSB for the processor you wish to choose.
You can cause SERIOUS damage to your computer if these settings are not just right.
(If you do decide to flash bios, be very careful. Make sure you download the right version or your pc will be useless).
Good luck,
Hank
Posted on Jul 29, 2009
Which version of Award BIOS supports HT?
I suggest to visit the manufacturer's website. If manufacturer has changed BIOS or Update the BIOS, the patches or new BIOS will be available there.
Jan 25, 2016 | Intel Computers & Internet
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
PC won't boot after upgrading cpu
either you have bought an incompatable chip for the mother board. or your power supplie is not powerfull enough I know this sounds stupid but it happened to me when I upgraded to a P4 3.6 quad core I installed the lot and it wouldnt start up I had a good power supply too Get your self at least a 500 watt PSU
Hope this helps
Apr 20, 2010 | VIA P4MA Pro Motherboard
Packard Bell IMedia 5055: GA-8SIML will not post or boot. Removed all PCI cards,RAM,Hard drive, optical drives etc. Only CPU and mobo but no post/BIOS screen. CPU fan runs and front panel LEDs work. Do get...
Put just the ram back into the motherboard, the pc will not boot without processor, ram and graphics pluged into the board, check this, if it will still not boot and you still get 3 beeps its a memory(ram) problem, and you will need to replace the memory stick.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Need motherboard manual for a gigabyt GA-8SIMLNF please can u help thanks
I set up this same mobo after my old one died and this was all I had. The manuals are fine except they have more pins than my mobo. Mine only has 9 pins, 4 at the top and 5 on the bottom. I got it to power on with the POWER SW on the top right hand 2 pins, positive to LHS I think. It doesn't matter if they're around the opposite way as it won't damage the board. The bottom left hand 2 pins are your HDD LED and the next 2 pins are your RESET SW. These pins are positive to RHS. The bottom 5th pin on the far right is not used. I tried all combinations on the 2 top left hand pins for the PWR LED but got no result so just left them off. I tried a P4 3GHz but it would only turn on for about 5 seconds then shut off. Maybe the BIOS is set only to accept a Celeron CPU. A BIOS upgrade may be in order.
Jun 26, 2009 | Gigabyte Computers & Internet
What is the correct connections for Packard Bell GA-8SIMLNF motherboard Front Pannel.As I can't read the markings on the board
Hi willow422,
I understand that you need the pin configuration for your front panel. This link will help guide you setup your front panel.
Link:
http://support.packardbell.com/uk/item/index.php?i=spec_columbia6&ppn=P862000601
Jun 16, 2009 | HP Computers & Internet
Uppgrade of processor!
looks like that mobo can only suppoport up to 53 mhz front side bus for a celeron d processor
wht tht means is tht u can get any cpu tht has the front side bus up to 533mhz with the 775 socket forur motherboard
and forpentium 4 its 800mhz and agian any cpu with up to 800 mhz front side bus and 775
so ur best cpu for tht mobo would be the SL7RR it supports hyperthreading
here a direct link to intel'ssite
http://processorfinder.intel.com/details.aspx?sSpec=SL7RR
SL7RR
3.40 GHz
800 MHz
109.6 W
66
512 KB
2 MB
775
0.13 µm
yes
pls rate my answer if i helped u
Sep 22, 2008 | Computers & Internet
Ga 8simlnf ram upgrade
There is no motherboard with this model number. Can you recheck this by looking on the board itself. Its right in the middle of the board.
In general though, you can usually put 4GBs of Ram in the G8 series but only Vista and later Linux versions will actually report above 3GBs.
Please reply using the comment box below. Thanks.
Regards,
Worldvet
Aug 17, 2008 | Intel Motherboard
CHIP UPGRADE
Hello there.
As per here , the largest cpu supported is the 1.4GHz Pentium 3.
Hope this helps.
Jul 07, 2008 | Gigabyte GA-6WMM7 Motherboard
Foxconn 661FX7MF-S Motherboard Logo
293 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
