Go to searspartsdirect.com type in your model number then to left be sure to
Click on select then click model when model info comes up select manuals and repair help you will have to type in model again in lower part of screen. You will then have to download one of the best owner's manual I have seen but no wiring diagram maybe enough info. To help you.
SOURCE: wiring diagram for model 137.248830
SAME SAW I HAVE, I ASSUME YOU DONT HAVE THE ORIGINAL OWNERS MANUAL. GO TO SEARS.COM, AND TOWARDS THE TOP THERE IS A "PARTS" HEADER. CLICK ON IT AND ENTER MODEL NUMBER WHEN REQUESTED, THEY WILL ASK UP IF YOU ARE LOOKING FOR A SPECIFIC PART OR MANUAL . HOPE THIS HELPS
SOURCE: old craftsman riding mower, need info.
That # does not pop up when i do a search. Please look at it again.
SOURCE: Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
SOURCE: I am looking for a wiring diagram for a simplicity
Could you please specify the product please.
I will need to know the Make and Model name please.
