Question about LG Washing Machines
Tub won't spin in lg washer wm0642hw frontloader motor and pump are fine
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
  • 351 Answers
SOURCE: roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Posted on Mar 20, 2008
  • 1028 Answers
SOURCE: Washer Won't Spin
ck under agitator pull dispenser out remove large wing nut dowm center of agitator pull up ..nothing there remove rubber pluggs each side of top remove phillip screws lift top pull tub ring off at tabs along edge and remove.. basket lifts out ck under it
Posted on Apr 27, 2008
SOURCE: LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Posted on Mar 14, 2009
localwonder
  • 6784 Answers
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Posted on Aug 08, 2009
LG WM0642HW
make sure it drains the water out..it will not go through spin if there still water inside the tub... also drain is timed. Is there any error message? thx
Mar 01, 2014 | Washing Machines
Lg frontload clothes washer WM0642HW won't drain during wash cycle. says OE code.
Drain strainer maybe clogged or drain motor dead or there is obstruction inside check hoses
Aug 27, 2013 | LG Washing Machines
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Will not rinse and spin Very tempramental Have drained cleaned both filters
for any frontload washer to drain and spin two things must happen first doolock mechanism must lock and drain pump must start draining before anycycle can beging . what about checking for blockage between tub bootom hose to pump squeese hose with hand to feel any blockages to pump if no blockages replace pump. I beleive u need to replace your drainpump.
Jan 23, 2011 | LG WM-2277HW Front Load Washer
HAVE A LG WM0642HW WASHING MACHINE & TUB STOPPED SPINNING. I CAN HEAR THE MOTOR COMING ON BUT TUB JUST DOESN'T SPIN. ANY SUGGESTIONS? THANKS
It is possible that the tub is mechanically struck within that is making the motor slip off from the drive. It is important that the voltage to the motor is checked ,if the voltage is not good then the program controller must be checked.
If not the motor by itself must be checked, if the motor spins then the drive assembly must be overhauled.
Nov 02, 2010 | LG WM0642H
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
Kenmore frontload works with no load but fails with clothes
Suspect the drum motor. Sounds like a burned winding in the motor which will open when hot and not work under any load.
Mar 26, 2009 | Kenmore 24032\24036 Top Load Washer
Mar 06, 2009 | LG WM-2277HW Front Load Washer
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
