SOURCE: Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
SOURCE: WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
SOURCE: Whirlpool 465 accubake gas range stuck in the "lock" mode.
Hi, Try setting it to clean, then cancel the clean cycle right away. Sometimes this helps. Please let me know.
Thanks
Vic
SOURCE: Whirlpool Super Capacity 465 Electric. Left Front
there are 3 screws under the front of the top with the oven door open actually there are 6 screws but only 3 you need to remove to raise the glass top up!! to service the burners
Hello
& Welcome to FixYa
The
problem is with the door lock assembly that is bad and needs replacement. Please
get back to me if you have any other questions.
Kevin
