Question about Harman Kardon HK 3375 Receiver
Very low sound.checked voltages +15ok -15ok ,5volts ok.it seemed like no sound at all.But if you turn volume all the way up i can hear sound just bearley (music)
    Problem Solver:
  • 10 Answers
Check the cables. check the input.
Posted on Jul 28, 2009
Can i repair this problem, has picture no sound
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Nov 02, 2014 | Televison & Video
I have an optimus stav 3670 stereo reciever that wont turn on. I have located 3 fuses, all test good. No lights, click, or any sound or reaction when power button pushed. I'm hoping there is a 4th fuse...
Mike, sounds as if it's not getting voltage to the remote control receiver circuit? Meaning that there is a low voltage (5volts) that sits there and waits for the signal from your remote to turn the unit on. This is also through the front power switch which is also tied to your on-off power relay. I would check for 5 volts around that. More that likely you a 5 volt regulator shot. Hope this may help?
Nov 25, 2013 | Dryers
Low volume on incoming calls
remove battery from phone and reinstall after 10 mins... this seems to fix alot of things also go to sound setting a make sure the volume is turned up all the way
Jul 09, 2012 | Apple iPhone 3G
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Jun 14, 2011 | Televison & Video
Kenwood TS50 - Max volume gives very low audio while receiving
It sound like a bad reostat in the volume control. if its under warranty send unit back to kenwood and have them replace the volume control, and possible speaker involvement.
Jul 12, 2009 | Radio Communications
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Problem with amp?
Give that new sub a chance to "break in". New speakers require a few hours of use before the voice coil(s) and spider break in and began operating at their best performance. Is the box within the operating specs of the sub? Is this a ported box; if so you will here some turbulance type noise from the port. What type of distortion are you hearing? Alternator noise(dentist drill like sound) would only be noticable through a sub at lower volumes due to the frequency response of a sub. Is the amps lowpass crossover turned on?
Mar 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Deck is powering off every 5 seconds
If radio stays on at low or no volume and cuts out when turning up you may have your battery backup voltage (yellow wire) droping below 10v under signal load. There is a circuit called backup check in radio that moniters Voltage It may seem ok when measuring without volume but under load it will fluctuate with the audio. Try hooking up Heavy guage Ground and Backup battery wires to prevent voltage loss across wires under load. Also check for any speaker that may not be producing proper sound when and if you can get radio working Disconnect wires to that speaker to see if radio will stay on. Just a couple of many possibilities.
kstahl65@att.net
Jan 12, 2008 | JVC KD-S890 CD Player
Ticking sound
ticking sound (like a Watch) coming from around the Flyback Transformer but I don't see a spark is called EHT voltage . if eht voltage is ok 1 check filament is glowing or not if it is ok check voltages on crt. 2 if it is ok check luminance section in chroma section. if filament is not glowing check for low eht due to hor section check power supply output also. good luck
Sep 18, 2007 | GE 25GT270 TV
Harman Kardon HK 3375 Receiver Logo
91 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
