SOURCE: Panasonic reverse cycle aircon.
Found the codes are printed inside the air conditioner.
F33 ---01. = locked up compressor.
Cannot fix this problem myself, will have to engage a serviceman.
Stan.
SOURCE: aircon not working
The F8 Fault means that the Temp sensor in the indoor unit that goes into the cooling coil is faulty.
SOURCE: display shows p2 on aircon
1、Check whether the resistance of the sensor is
normal (the resistance is 5Кω in the normal
temperature 25℃), when it is abnormal the sensor
should be replaced.
2、Check whether there is short circuit or open circuit
in the wire of the sensor, and whether the plug is
connected well, whether there is welding off or
rosin joint on the electric control board, if there is
any, it should be repaired.
3、When the 1 and 2 are both normal, then the
components or integrated circuit is damaged, the
electric control board should be replaced.
