Question about Hoover Washing Machines
Hoover visionhd 7kg vhd8144d when clothes go into spin cycle, I get a knocking sound like it could be shockers or springs weak or something has come loose, don't know what it is.
  • 183 Answers
SOURCE: Hoover 2305 washine machine wont spin
Your problem could be caused the interlock but it could also be that the machine is failing to drain in the time alllowed and therefore the machine will not spin, before buying a lock check the sump hose and pump area for blockages.
Posted on Dec 30, 2007
  • 1294 Answers
SOURCE: Washer spins but not enough to extract water from clothes or tub.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 31, 2007
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Posted on Sep 17, 2008
  • 58 Answers
SOURCE: Model MAV3855AWW revision 26
The problem is 2 fold. The "knocking" noise is indicative of brake rub. The fix is to replace the rotor & stator. The reason that your clothing are coming out wet is because the brake is dragging along a polished stator when in spin and cannot get up to its proper speed as a result. The 2nd item that should be replaced is the thrust bearing assy. This is what enables the transmission to transition from agitation to spin... Hope this helps... Bill
Posted on May 18, 2009
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
My Hoover 750L starts its spin cycle but when goes to a really high spin it makes a noise.
Check your mounts and support springs---one of them maybe broke or loose---since you haven't described the noise this is the best i can come up with. GL
Sep 18, 2017 | Hoover Washing Machines
Fitted new motor to a commander 7kg A6928 agitator spins but bowel stays still in spin setting why?
sounds like maybe a thrust bearing in the hub at bottom of agitator not engaging? are u saying the hub does not spin but the agitator moves?
Oct 31, 2014 | Hoover Washing Machines
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
When spinning, Out of balance message occurs, then the machine starts to add water to get the load out of balance. It will put additional time on the wash cycle. It will drain and try to spin again. Then...
it could be weak shocks for the drum or the springs. you can also overload the washer. there should be a gap in filling washer with clothes around 5-to 6 cm's on the drum ring this gives space for movement and balancing. the washer can also become out of balance if the bearing is damaged, if you can lift the drum from the bottom of the ring and it moves up and down by few millimeters and feels lose then its usually a sign the bearing is weak. this can make the display say there is a problem with balance. 6kg or 7kg is the weight of the clothes and water not the clothes. over loading the washer damages the bearings and put more pressure on the shocks and springs.
Jul 03, 2017 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Model MAV3855AWW revision 26 loud knocking sound during agitation, weak spin clothes are soaked after spin cycle belt replaced
Apr 30, 2008 | Washing Machines
Jun 24, 2007 | Hoover HTC243 Top Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
