Need the pin setup for power switch intel 411726100004 motherboard
  • Jim Thurston May 11, 2010
    Can you give me the MOBO model number? It will be a number like D850MV.
  • 596 Answers
This short cut should help you out.
http://download.intel.com/support/motherboards/desktop/D845PESV/SV_English.pdf
Good luck
C2Solutions
Posted on Jul 30, 2009
Gateway service manuals
from all the research I could find on this computer it looks like it has an intel motherboard in it I have attached a link to the pdf of the motherboard. Page 44 shows how the front panel should be wired. looks like pins 2 & 4 are for power light 6 & 8 for on off switch 1 & 3 for HDD light and 5 & 7 for a reset button
http://downloadmirror.intel.com/15197/eng/D915GAV_D915GAG_D915GEV_D915GUX_ProductGuide02_English.pdf
Jun 28, 2014 | Computers & Internet
I have an MS-7502VER:1.2 motherboard and i cannot find wher to plug the power switch into
Hi scouts692
The Front Panel Header Pin arrangement for this motherboard is unusual, in that the header only appears to have 8 pins in a single column rather 2 parallel columns of 6 Pins with 1 blank, as most conventional motherboards do.
Pin 1 is POWER SWITCH orange or red (PWR SW 1)
Pin 2 is POWER SWITCH white or black (PWR SW 2)
Pin 3 is POWER LAD + (PWR LED -)
Pin 4 is POWER LED - (PWR LED +)
Pin 5 is HARD DRIVE LED - (HD LED -)
Pin 6 is HARD DRIVE LED + (HD LED +)
Pin 7 is RESET SWITCH blue or green (RST SW/RST 1)
Pin 8 is RESET SWITCH white or black (RST SW/RST 2)
Please refer to a PDF of the Motherboard Manual for additional information about the setup of this motherboard (the relevant page for the Front Panel Header is page 17/Section 2-13)
hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 17, 2011 | Intel Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
How to cnnect the light cables Power and reset............etc of intel mother Board d815EEA
Connector number J9C1 - power LED pin 2-4, reset switch pin 5-7.
1-3 - hard drive activity led, power switch 6-8 pins.
Connect and enjoy :-)
Aug 10, 2009 | Zerus Intel Desktop Board D815EEA...
I cannot acces my computer stays at intel screen
Open the computer, and you will see near the bottom right corner a blue jumper on 2 of 3 pins. The pins are J9J4 and the jumper should be on pins 1 and 2.
Turn off the computer and the power supply, remove the little round battery from the motherboard, move the blue jumper to pins 2 and 3 and wait 40 seconds. Reinstall the battery, and then move the blue jumper back to pins 1 and 2.
Turn on the power supply, restart the computer and the BIOS settup utility should appear
Apr 16, 2009 | Intel D865GLC Motherboard
My PC is connected to UPS.Whenever I switch on my UPSthe PC start
On the mother board at the front are 2 rows of pins to which wires are attached, going to switch(power) and the manual reset and the LED's. Usually the first 2 sets of wires--pairs of Green&White and red/black&white are for power and reset. Once u pull out the jumper-like attachments u will be able to see whats written on them. Isolate the power & reset wires. Remove them fron the pins on the motherboard. Switch on ur UPS and by simply shorting 2 pins, starts the PC. Now that u have identified the power pins, put them back after cleaning the dust,etc. If the PC behaves as before but works perfectly when the power switch connections are opened & PC works normally after just touching the 2 oins, then the switch need to be replaced......sodeep
Mar 31, 2009 | Intel D915GLVG Motherboard
Connecting front panel wiring to INTEL 845GRG Motherboard
Hello davideiker1, the Intel D845GRG MB manual is shared with another Intel board. (D845GBV MB). Go to this Intel site & download the D845GRG manual; http://support.intel.com/support/motherboards/desktop/d845grg/sb/cs-008873.htm You'll need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
See page 9 for motherboard layout.
The front panel connectors are shown on page 68, see item C.
On page 69 is, Table 31 shows the pin assignments for the front panel header. Front Panel Header (J9G1).
Pin 1 is power for the hard disk drive led, pin-3 is negative for the hard disk drive. Wire colors coming from the case are important. Look at all of the front case wires. The common color for each 2-pin connector will be ground. In most cases the ground wire is white, except for the internal speaker. Ground for the speaker is normally black. (This motherboards speaker is built into the MB, no hook up is needed).
Pin number 2 is positive for the case power led which lights up as green. Pin 4 is negative for the power led.
The reset switch is a bit different. Pin 5 is negative & pin 9 is positive, however if your case uses a two pin connector than connect pin 7 as ground & pin 9 for positive. The On/Off switch, pin 6 is positive & pin 8 is negative.
If this manual is not what you see on the MB, please advise.
Good luck davideiker1!
Need more information/questions post here.
Thank you for using FixYa.
Input, comments are welcomed.
Mike
Jan 22, 2009 | EliteGroup P6SET-ML Motherboard
Found power switch
Do you mean the pin set on the motherboard to connect your power on button's wires to?
This connector labeled: FPBUT_IN In Power switch connects to pin 6 and 8
Find Pin 1 and count down and then next row count down. Sounds like this connects to the second row and there should be no pin for pin location 7
This is the link to download the board PDF manual, go to page 78.
Your Motherboard has a different number assigned by Intell but is the same as yours.
Regards,
Worldvet
May 24, 2008 | Intel Motherboard
How to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Apr 25, 2008 | Intel Desktop Board RC440BX...
Can I replace a 40gb HD w/a 80gb HD
Your motherboard supports 80gb Hdd.No problem you will go for that
Jan 23, 2008 | Computers & Internet
Computers & Internet Logo
457 people viewed this question
David Payne
David Payne
