Receiver will click off
My receiver clicks off when the volume goes up and click back on. the power stays on the entire time and the equilizers are working and the cd is not skipping, it also does it when connected to mp3 player. So when I turn the volume up a little it will make a clicking noise and the music goes away, comes back, goes away etc. as if the cd were skipping but it is clearly the receiver.
  • 35 Answers
Check your power supply to make sure the correct amps and volts are there. check your speakers to verify the correct ohms for the receiver. if the ohms are to big you will shut down because it overdraws on the receiver.
Posted on Jul 28, 2009
Onkyo ht r591 keep clicking on/off
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
Oct 11, 2015 | Onkyo Audio Players & Recorders
Pioneer vsx-521-k power goes on then off
Sounds like a short in the amp that will need to be repaired before the unit will stay powered on.
Feb 25, 2013 | Pioneer VSX-455 Receiver
I have a sherwood s-7200 receiver. The power knob will not "click" to turn off the unit...it just stays on. The powe knob is also the volume control. All functions work as normal except the receiver will...
Known issue with these models. There's a plastic washer cam thing in the back of the switch that breaks. Since no new parts exist, you much make one to fix it. Or, just use a power strip to turn it on and off.
Jun 24, 2010 | Audio Players & Recorders
When i push power button clicks on immediately
I had this problem also and discovered an easy way to trick it into powering on: Click the power button, then within 1 second of the receiver powering off, click the power button again. The receiver should stay on this time. This works with both the button on the receiver and the remote control.
I would like to know what causes this problem and whether or not I should be concerned about damage being done. I assume this is a power protection. I haven't tried plugging this receiver into a different power socket to test, but I don't think the power plug is the problem. Note: I have the subwoofer plugged into the power plug on the back of the receiver.
Feb 23, 2010 | Onkyo HTR500 Receiver
It turns off when the volume is turned up over one third of the volume knob, but is the speakers don't interfere in any way
sounds like the protection circuit is the problem here which is a good thing because its stopping you from permantly damaging the unit first thing to check would be the impedance of your speakers and then check what your impedance selector is set to on the back assuming you have one be warned that you should never move this switch while the unit is on.My advice would be to unplug it first because that switch plays a direct role in the systems power supply..Hope this works for you
Oct 31, 2009 | Technics SA-AX540 Receiver
How to connect old 901 Bose equilizer to amp/receiver
If you plan to use them with a home theater, you will need a seperate amplifier, as most a/v receivers don't have tape monitors. With an integrated amp hook rec out to the input on eq hook output on eq to playback on tape mon. with seperates hook pre amp out to input on eq, output on eq to power amp input.
Jun 23, 2009 | Bose 901 VI Main / Stereo Speaker
Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Mar 02, 2009 | Yamaha RX-V1400 Receiver
Volume goes down to nothing
hi, the problem of your receiver is in the amplifier section the idle current is not working that is why the volume fades and the protection relay click to avoid further trouble of your receiver,you need repair technician to solve your problem.
Sep 11, 2008 | Onkyo TX-8522 Receiver
Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Feb 21, 2008 | Yamaha HTR-5940 Receiver
Denon reciever
Sounds like you are exceeding the maximum power output of the receiver. Try disconnecting some speakers (and switch to A-only mode if your model has multi-zone) and see if that makes a difference.
Dec 31, 2006 | Denon AVR-2801 Receiver
60 people viewed this question
 Grubhead
Grubhead
