Monitor will not come back on.
The power went out to the house. Apparently it was out for a few hours. When I returned home, I turned the computer on. The monitor (LG Flatron W2252TQ-TF) will not come on. There is no light on the front. When I press the power button nothing happens. I have checked the outlet with another appliance and it is live.
  • 120 Answers
The monitor experiencing to much input volgate when the power came back. The power fuse or some parts got damage. Bring your monitor to expert technician for repair.
Posted on Jul 28, 2009
  • 748 Answers
Hello
Some LCD monitors do have internal fuses but in almost every case they are not user serviceable. If you don't feel comfortable opeing the monitor then you can send it to a company like mine or take it to a local service person.
2004 Audi Allroad Power window problem
Possibly a faulty driver door switch. There is a function tied to switch allowing driver to open or close all windows through door switch.
Dec 27, 2012 | 2004 Audi allroad
My monitor has gone a bright blue
Check the pins in the end of the monitor cable, look for bent ones. If it's okay re connect to the monitor and try again. Unplug the monitor and wait for a few seconds, plug power back in. Cycle power on the monitor. Then restart your computer. Wiggle the monitor cable on either end and see if the color changes.Good luck
Sep 30, 2012 | Microsoft 66I-00752 WINDOWS VISTA -...
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Power to house went out during area power outage. Everything came back on except the computer? Tries to restart by holding power switch in, unplugged and replugged power cord - no response on monitor. ...
When the power is returned after a power outage it can cause a power surge and damage electronic equipment such as a computer. This is a reason to install a surge protection power board and connect your computer equipment to a surge protection board.
The switch mode power supply may be faulty and replacing it may get your computer operating again.
If you cannot DIY then ask a friend or take it to a computer repair shop.
Jul 14, 2011 | HP Pavillion s7420n PC Desktop
After using my home computer for an hour or so and then leaving, but it is still on and when I return in 2 hours the screen is black and will not return to home page when mouse is touched. I have to turn...
OK you need to change your power settings. This decides what your computer will do when left for a period of time, it may be best to change everything to always on if you cant wake it up from hybernation, check here Control Panel\All Control Panel Items\Power Options
Sep 12, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
Monitor goes to sleep
go to control panel, display properties, screen saver, turn off,
than go to power options, turn off the "turn off display" option.
Jun 06, 2009 | HP Computers & Internet
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Computers & Internet Logo
367 people viewed this question
David Payne
David Payne
