Question about Dometic Rooftop RV Air Conditioner
Roof air unit too loud inside; quiet outside.
We have had our Rockwood Windjammer for 1 year now. It has a 13,500 roof air Dometic DuoTherm. We have noticed that the operation inside is very loud. Our Mallard did not make half the noise & was same size unit. What would be causing this too be so loud? Have to talk very loud while it is running.
  • Dometic Master
  • 6,674 Answers
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Posted on Jul 28, 2009
Cannot get tv to work with outside connection. Both inside connection work. What is the problem.
One thing to make sure is that the cables are actually attached. Take the outside connection apart and make sure the cable is attached to the plate. I worked on RV's for years and this happens more than you think.
Sep 24, 2014 | Forest River 2014 Rockwood Windjammer...
My dometic aircon is very quiet outside but inside very noisy and vibrates throughout motorhome
You may want to remove cover on roof and inspect for mudwasp nests on shafts, fan blades, blower wheel etc. Quite common for that to happen and cause vibration. The nests throws off the balance.
Mar 06, 2013 | Heating & Cooling
I have a 1981 rockwood camper popoup recently started leaking ,i have damagae inside camper(ceiling).also repair outside as well and latches& roof need to be fi.what do i do?
First thing you want to do is to find the source of the leak(s) and seal it to prevent further damage, and if not possible to get it inside, at least get a tarp over it to stop further moisture from entering. In all honesty, they are not real difficult to repair, you just need a place to remove the roof in order to replace damaged parts. Easiest way is to remove it from trailer, and go from there. If outside and sides as well as ends are still good and solid, then it's just a matter of replacing ceiling panels, which wouldn't require removing roof, but by sounds of it, if latches are falling off, and wood is rotten behind them, it may be time to rebuild sides etc. Let me know how bad it is, and include some pictures if possible, and we can guide you through it. Be sure to take pictures before, for your own reference when re-assembling.
Oct 03, 2011 | Dometic Rooftop RV Air Conditioner
Can the outside unit in a split system be located higher than the
The outside unit is on the roof. If possible,get a ladder and get on top and you should see unit. To clean unit,remove screws on the sides, remove top cover.If coils are dirty, spray with a garden hose to clean.
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
Neither Roof Air Works
Yes and no .. Freezing temps should not affect your A/C at all ... BUT .. there is a freeze control box, its called a control unit to prevent itself from freezing up and burning out, take down the lower cover and you will see it. Your problem is more likely to be more central since neither are working Thermostat or even the control box's in genera, even could be a freon problem if the cold weather was really bad and you could have a leak on your lines, check it out and see what you got!
Dec 31, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III 13,500 btu ducted roof air conditioner
Did you plug upper unit (on roof) into lower control unit (inside). Not to insult you, because i've done it myself, in a rush situation. Breaker on? Sure you didn't mix up any wiring?
Jun 29, 2008 | Coleman Mach III Air Conditioner
ROOF AC UNIT ISSUES
Ice on the coil is caused by 3 things; 1, low freon charge. 2, inadequate air flow across the coil, this can be a filter or dirty coil (I think you addressed these) or the fan isn't blowing enough air over the coil. 3, the unit is running continuously. A heat pump has another cause, that is something defective in the defrost system, like the sensor, reversing valve, control board or relay. If the breaker is tripping its because the compressor is over amping. There can be an obstruction blocking the fan or something like #2. Or the compressor is going out. If the breaker doesn't trip on other settings, like cool, but trips on heat, then I would look at the airflow.
Mar 14, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
963 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
