Question about Chicago Pneumatic 1/2" Air Impact Wrench
Loaned impact wrench tried to use after returned will not stop rotating unless air is unplugged
    President:
  • 583 Answers
Typical ---get it serviced there is small platic type o/ring on trigger in the handle that gets brittle and breaks up,mine went just after easter ..make sure ,when fixed to add a few drops of transmission fluid to th e air inlet every time you useit
Posted on Jul 29, 2009
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
My CP impact wrench run fine when not removing a bolt. When removing the bolt it turns it a few rounds then stops
Try a good cleaning with diesel fuel. Keep adding diesel into air inlet until the fuel comes out clean (add diesel then connect air to blow it out) . Once clean, add several drops of oil and retest. If it works better but not full power, try another cleaning with wd40 and retest. Good luck
Oct 16, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
Impact wrench will not reverse
Hi sureputtcup...
Try this solution:
Spray some WD40 into the air intake of the impact wrench and then hook up your air hose to the wrench...run it a few seconds in forward....then after running in forwards for a few times, disconnect the wrench again, and again spray a small amount of WD40 into the air intake of the wrench...again run in forward...after running in forward again, then try to reverse the rotation...turn to reverse..
This will sometimes free up the vanes and sticky parts and allow the wrench to work properly.
If this does not work then you will need to disassemble the wrench and clean and oil and reassemble.
Please take time to rate me 4 thumbs up
Sep 03, 2011 | Garden
Model 734 1/2 in impact.wont blow air ,wont rotate,no tension on trigger.feel like problem may somehow be in trigger housing....
Yes, if you take it apart you'll find that the trigger isn't allowing air to pass through to the veins of the impact wrench. It's a relatively simple mechanism, where maybe something is broken inside.
If it were blowing air but the veins were stuck, I would say, lubricate it. But, if no air goes through it at all, then the trigger housing houses the problem part.
Have you tried to disassemble the air wrench?
Jan 21, 2011 | Chicago Pneumatic 1/2" Air Impact Wrench
I have no problems in reverse but gun seems to stop when trying to tighten. Had the same problem with my 1st 2135ti
Sounds as though you have broken or worn hammers. Try KCTool 715 445 7700. They can and will help you.
Oct 26, 2010 | Ingersoll Rand 2135Ti Air Impact Wrench
My Aircat 1404BG impact gun stopped working.
most of the problems accure from being dry try 2 or 3 drops through the air intake fitting every so often depening how much you use your air tools, it may be time for a new one but i would try the air tool oil first before bying a new one, i hope i helped.
Jan 02, 2010 | Impact Aircat AC1603 3/4" 1330 Ft - Lbs...
Craftsman 1/2 inch impact wrench,not working
Make sure you have at least 90 pounds of air and if you do you need to oil the wrench air tool oil pour some in the where the air line hooks up ..air tools need to be oiled daily cause compressed air cause water vapors to build up when you use it and then when it sits it begins to rust a bit and the oil stops this ...
Nov 14, 2009 | Craftsman 1/2" Impact Wrench
This is an older model FW-20h. The air pressure is 150 psi but does not turn the rotor
go get some wd 40 unless its totally locked up as in you cant turn it by hand, then one or more internal vanes are jammed inside on the rotor
Sep 29, 2009 | Impact Fuji Air Tool Fw-14px-5 Wrench
Impact wrench never stops spinning!
you have a bad o-ring at the air inlet
Apr 16, 2009 | Impact Husky® 1/2" Wrench
Chicago Pneumatic  1/2" Air Impact Wrench Logo
368 people viewed this question
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
