Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Runs fine for awhile,stalls, won't start , when it starts , when
In gear won't move
  • ed in oregon May 11, 2010
    need a little more info here - the header and the symptom don't seem to match and the description isn't real helpful
  •  Corey A
    Corey A May 11, 2010
    Engine running? Brake released? Clutch engaged?
    Problem Solver:
  • 4 Answers
Replace the fuel shut-off solenoid (it is installed in the bottom of the carburetor float bowl). ensure you get the right one for your mower as there may be different parts for the same tractor p/n. had this problem recently and it drove me wacko.
Posted on Aug 30, 2009
Rough idle after engine is warm
Dirty air filter, dirty throttle body...try 2 bottles of gas line fuel injector cleaner...has your car been parked for awhile? Heet gas additive will work on any low gas tank sludge that you may have. Hope this helps.
Mar 24, 2014 | 1999 Mazda 626
I have a 1993 dodge dakota that will not run when I put it in gear. If I let it set for awhile (2-3 hours) it will start right up and idle for as long as I want without missing but as soon as I put it into...
Check fuel filter, relay, fuel pump, sometimes the pump will run, but still too weak to run an engine at speed or underload. If fuel pressure checks out to be fine, look for a clogged catalytic converter.
Dec 15, 2013 | 1993 Dodge Dakota
Cub cadet 1517
Sounds like there's a problem with the diaphram in the carb. May bet letting to much fuel through which then stalls it.
Jun 27, 2013 | Garden
2002 Kawasaki ZX-6R is stalling when the clutch is disengaged
Hi, Jesse the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Bike stalls when clutch is disengaged
zx6r 05 when put in gear engine stalls
Kawasaki 2000 Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Nov 03, 2017 | 2002 kawasaki ZX-6R
1997 Suzuki Intruder VS800...starts, runs, stalls
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Intruders Alert
Total Motorcycle Forums
Suzuki VS700 Service Manual
OEM parts for Suzuki
Suzuki VL800 Owner Manual
May 12, 2017 | 1997 Suzuki VS 800 Intruder
94 trailblazer runs really rough for awhile after sitting ,after running awhile its starts to run fine (worse on cold days) help please!!!
Have a pressure bleed down test run on the fuel pump, that is the most common problem that causes this condition.
Aug 23, 2012 | Cars & Trucks
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
1987 300 zx starts the quits after 2 minutes and won't start again
probally crank sensor. starts then stalls after driving a few min. then won't start for awhile. u can actually check it on the ecu. 4 green lights then 4 red lights. if you can't run the comp check on ecu let me know i'll look it up its been awhile had same prob years ago all my sensors are new
Oct 28, 2011 | 1987 Nissan 300ZX
Car hesitates/stalls when engine is warm and car starts to move.
Sounds like a bad motor mount, pop the hood and see if the motor shakes or moves rapidly when u put it in gear holding down the brake.
May 10, 2009 | 2001 BMW 325
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
184 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
