Question about The Office Equipment & Supplies
Interrupt button is flashing on my WorkCentre 3655 and the machine won't power up.
    New Friend:
  • 3 Answers
You have a minor problem you have to replace processor behind the ink cartridge.
Posted on Oct 03, 2017
Testimonial: "Thank you!"
SOURCE:
Sharp AR-M205 Calling for Maintenance. How do yuo reset?
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
Sep 17, 2008 | Sharp Office Equipment & Supplies
Error code 116-330 xerox workcentre 5325
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
Jan 10, 2016 | Xerox Workcentre 5325/c 5325 Black & White...
I have a WC5225. When I switch on the machine the interrupt light keeps on blinking and the machine does not boot.
Try this: 1. Turn machine off 2. After it has completely powered down, unplug the power cord from the wall. 3. Go back to the front of the machine and turn it on and then back off again (remembering to leave it UNPLUGGED from power.) 4. WAIT 60 SECONDS (Very important) 5. AFTER 60 seconds plug it back into the wall and turn it back on.
If problem persists call for service.
Hope it helps!
Apr 30, 2011 | Xerox WorkCentre 52255230 Copier
Canon ir 3300 ,this has E000019-0000 problem ,how to solve it
canon ir3300 error code E000019-0000, hOW CAN I SOLVE IT ???
NO KEY IS FUNCTIONING NOW.................
mail at chandaxerox@gmail.com
Feb 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Error H-4
H4-00 on Sharp means that the temperature inside the printer is too low. That is usually the fuser lamp, and sometimes the temp sensor jammed.
Only when the problem is a jammed temp sensor or a jammed control board you can reset the machine by doing a reset.
You try reset from simulation mode by following procedure below:
Clear key >>Interrupt key >> "0" key >> Interrupt key >> Main code >>Start key >> Sub code >> Start key
If the error remains, that means that the fuser is really bad and must be replaced.
When this happen you need to have the fuser unit replaced, if that does not fix the problem the technician will replace the temperature sensor.
Mar 01, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Machine doesn work. H4 keeps flashing
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 13, 2008 | Office Equipment & Supplies
Sharp AR-287 Copier error code H5-01
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Mar 17, 2008 | Sharp AL-1641CS Laser Digital Copier
2,286 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
