SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
SOURCE: my clothes are stuck in my front loading whirlpool
The following link explains how to open the door manually on a Whirpool Duet:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have questions, or require additional assistance, please let me know. I hope this helps you.
SOURCE: Front loading washing machine door is stuck, won't
press hard on door to free handle do code means door sw. not made or bad
SOURCE: my front load washer has the door lock stuck and
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
SOURCE: bosch front loader washing machine door not opening
The door will not open if the machine detects excess water in it. Run the drain or spin cycle to check if water is being expelled. If necessary check the pump filter for obstructions and the outlet hose for blockages. If this does not work you may have a problem with the pressure system, the door lock itself or a crack or break in the handle and it is not catching the lock mechanism, let me know if this helps or if you need further assistance.
Turn program selector to "off". Turn
selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start /
pause light flashes.
OR
First, unplug the machine
and turn off the water supply. On the lower right of the front panel is a
6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a
piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip
hanging down on the right; Pull down on this strip while pushing in on the
door, the door lock will release.
Pl click if helped.
