Question about HP Photosmart C5180 All-In-One InkJet Printer
Paper Jam that pulls paper to the right and crooked then get error message no paper
  • 748 Answers
Hello
You have either a rubber roller that has gone completely bad or more likely there is something still stuck in the printer - probably a piece of paper wrapped around part of the feed roller. Open it up and examine carefully with a flashlight. If you can't find any foreign objects then wipe down all the rubber rollers with denatured alcohol.
Posted on Jul 28, 2009
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Printer says to clear paper jam, can't see paper jam i clear it out.
Here is a post I found how someone else fixed their problem. Good Luck
I was getting the same fake paper jam and improper shutdown error messages on this POS printer. I blew it out with compressed air - but that was no help. To watch what was going on, I stuck a pen top in the open cover switch sensor (see top image at http://windowshopusa.com/hp_8500_POS.html ). It didn't appear that the cog wheel was the problem - it made no clicking noise or anything - the print head just traversed from R to L, then errored.
After I removed the sliding cover on the right, and with the print heads out of the way, I noticed that the chrome hold-down clip (bottom image) was crooked, and this prevented the print heads from traveling all the way to the right, causing the fake paper jam. Straightening the clip fixed the problem. (I didn't have to remove the clip, just pushed it straight - it's not in very tight.)
Nov 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Pulls paper in crooked and gets a paper jam error
get some cotton swabs and alcohol and clean the pickup wheels for the paper... you will have open the lid and remove the paper to get at them.
Mar 12, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I keep getting error message C000 which tells me to shut down the printer and restart it. How do I fix this. Thanks
1) Make sure the tank holding all the ink cartriges is properly aligned and can move side-to-side.
2) If it is crooked or can't move, check below it for a paper jam -- when the jam is that bad, the C000 appears to override the normal Paper Jam warning.
3) Make sure none of the ink cartridges has run completely out -- I tend to use them until they're bone dry, and got the C000 error....inserting a new cartridge cleared it right up.
Jan 29, 2011 | Canon Office Equipment & Supplies
Paper jam
try to add some paper to the tray ..maybe the paper pick mechanism has been failed..
May 17, 2009 | Canon Office Equipment & Supplies
Message: Error paper jam. There is no paper jam.
Yes there is some micro piece of paper is under a sensor somewhere Get serious and pull it apart, what have you got to loose! Inkypete
Apr 20, 2009 | Epson Stylus Photo RX500 Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
124 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
