Question about Sharp Microwave Ovens
Lower button - Start Minute Plus, does not return. Spring broken?
Lower button - Start Minute Plus, does not return fully when released. My question ''How to remove panel w/ controls? This way I can get to this button to repair or replace. Maybe a parts listing would be helpful.
  • 120 Answers
You have a bad spring and micro limit switch. You need to pull the cover in the front in order to remove that.
Posted on Jul 28, 2009
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
Microwave door alignment
test all this steps and fix it. God bless you
Oct 27, 2013 | Microwave Ovens
H5460NO/01 door lock is not working
test this steps and fix it. God bless you
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
Lock faults
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2aaubHCcG
Jul 30, 2013 | Sharp Microwave Ovens
How do you open the door
see this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2YvqJdpSm
Jul 13, 2013 | Siemens HF17055GB Microwave Oven
The door doesn't open
please follow the instruction and fix it. God bless you
May 28, 2013 | Cuisinart Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I've had mine for approx. 5 years and this year the buttons started to not work. I could only use the One Minute Plus button. This morning nothing worked! I unplugged it, replugged it and still nothing....
On these models, each of the four plastic buttons on the right side of the control panel runs a hidden pad on the membrane keypad.
The other pads on the keypad are fully exposed once you open the door and you just press them directly to operate them.
These plastic button assemblies have been upgraded due to weakness and breakage.
Most often it's the bottom two buttons (Stop/Clear and Start/Minute Plus) that fail.
You can order the button assemblies here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The service manuals you need to refer to are here and here.
Oct 01, 2010 | Sharp R-1502 Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
