Question about Panasonic PT-47WX53 47" Rear Projection HDTV
We just had our DISH sattelite system upgraded and the installer programed the DISH remiote to turn the tv off and on. 2 days later it turned itself off and it wont stay on, The tv comes on briefly and then shuts off but the power light blinks
  • suziwickham Jul 28, 2009
    its a 53 in rear projection model # PT-53wx42F
  • 120 Answers
What kind of TV you have and model too
Posted on Jul 28, 2009
After upgrade of software Phone turns itself back on even hours later
There is likely a process or application that is preventing your phone from turning all the way off, or it is turning your phone back on for its own purposes. Check the permissions of your installed apps to make sure none of them have that permission, and talk to Verizon to see if the recent upgrade may be causing the problem.
Nov 24, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Lost my Dish network remote for the upstairs tv (LG) - which has NO box. Is there anyway to program my TV remote, so I can access the TV staions - turn on the network basically???????
No,the Dish Network satalite box signals require it own remote for it INFER RED INPUT and INFER RED OUTPUT signals.Call Dish Network customer service ask for a another original Dish Network remote.U pay $5 or $6 dollars a month for the satalite box as rental.They should wave the fee or charge u very little for a another remote.
Sep 05, 2011 | Universal Remote Control Dish Network...
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
I have a dish tv disk at my home. I have troubling in dish tv channels just few channels are working like star news zee action national geographic and some channels like colors sony max tv are working in...
The problem with checking signal strength is you have to know exactly what sattelites are used and what transponders there on. dish net uses 119 and 110 and sometimes 61.5 your best bet is to check sattelite menu. Hit menu once that comes up hit button number 6, then button number 1 then button number 1 again. then you have to run a test switch its right in the middle, If it finds anything or low signal there will be a check details or error message in red on the bottom of the screen, it will tell you exactly what is wrong. Also one more thing is you can go to menu then hit button number 6, then number 1, then number 3. If the signal is good on the t.v. then it is probably what they call L.O. Drift or Lnb drift which that check will tell you, this is common for older dish systems especially super dishes, which are the big dishes if this is it then you have to schedule and appointment and they will upgrade your dish. If this is too much to take in, you can always call customer service they will walk you through the same thing step by step.
Sep 04, 2010 | DISH Network 311 DTV Receiver
I got dish net work installed yesterday and it worked fine but when i turned the tv on the next day it was nothing but static and i cant figure out how to fix it so whats wrong and how can i fix it?
Guest,
The static you are getting on your TV is because the TV is not on the correct channel or input setting. With the 311 receiver, there is either a coax or an RCA cable (yellow, white, red) going from the receiver to the TV. If you have a coax cable, the TV should be on channel 3 or 4 (usually channel 3). With the RCA cable, the TV should be on an input setting. You'll need to go through your input settings until you find the picture. Of course your DISH receiver needs to be powered on. I hope this helps.
Ray Calo
DISH Network
May 20, 2010 | DISH Network 311 2-Room System DTV...
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Sony - Projector TV won't turn
Sony TV;s will give a service code, count the blinks, eg; 2-6, light will blink X amount of times, hesitate & blink again so many times. Count and report back but, I would recomend to unplug the TV's power cord, to reset the TV's system. Unplug for at least 3 minutes. I hope this was helpful.
Jun 11, 2008 | Televison & Video
Changing sattelites
check this site
http://www.criscros.net/4dtv_setup_guides.htm
and
http://www.criscros.net/4dhelp.html
Apr 23, 2008 | Arris DSR922
Set turns itself on for no reason (and sometimes off)
on menu, pick customize, then set the video input sensor to off.
Dec 31, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
75 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
