Question about Saws
Looking for parts for a Rockwell 648 jig saw Type 1 Need the shaft that holds blade
    Problem Solver:
  • 15 Answers
Go to a hardwear
Posted on Jul 28, 2009
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
I need an owner's manual for a Rockwell 34-660 model table saw. I want to replace the blade but the entire shaft turns when I try to remove the shaft nut from the shaft.
You might be able to find a manual here.
You need to lock the blade in place so it doesn't rotate when you loosen the arbor nut. Many older rockwell saws actually had a detent ground in the shaft behind the blade that allow the use of a second wrench to hold the shaft from spinning while the nut is loosened. It takes a special thin wrench to get in there, and the ones that came with the saws were bent just behind the head of the wrench to get around the blade and out the throat, but if you know anyone with a delta tablesaw they may have one you can borrow, or perhaps you can grind down an old cheapy that fits.
If that's not the case, try the instructions I gave in this link.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 05, 2011 | Saws
Cannot remove blade as do not hve manual 4350FCT makita jig saw
Hello Aiden,
This Makita jigsaw does not use any set screw fasteners to secure the blade in the saw. It has a "tool-less" blade retainer, so all you need to do to remove (or install) the blades, is to twist the small knurled ring nearest the blade shank.
Be sure to unplug the jigsaw first and with the blade shaft fully away extended from the saw, (you can just pull it out by hand if needed) and then simply twist the round locking ring and then with your other hand, pull the blade out of the jigsaw.
I would suggest that you use a glove on the hand you're going to pull the blade out of the jigsaw with, as those blades can be very sharp with the jagged cutting edges, etc.
Here's a parts breakdown of the jigsaw, for your reference and for obtaining any replacement parts you might need in the future.
http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_4350FCT.pdf
Makita doesn't have an owner's manual listed on their web site for this product. You will need to contact Makita directly to obtain a free replacement manual for your product. You can contact them at
1-800- 4MAKITA (462-5482) Hours: Monday through Friday 8am - 6pm (EST)
I hope you find this Very Helpful and best regards!
Dec 23, 2009 | Makita 4350FCT Top Handle Jig Saw w/...
I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
Oct 20, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Jig saw model 7580 type 4, replacement for blade clamp
There is no model 7580 Jigsaw. The only model close to that I can see would be the 7588 Type 4. Unfortunately that part is unavailable for this model. You may want to contact your local Dewalt service center and see if there is a substitute for that part.
Sep 05, 2009 | Black & Decker Saws
Cannot get the blade in woolworth own make laser jig saw
If you look at the front of the tool down where the blade goes, do you see two allen/hex screws? If so these need to be loosened, a blade inserted up into the holder and the screws re-tightened to hold it there.
Jun 18, 2009 | Electric Jig Saw W/laser Guide
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Saws Logo
179 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
