Question about Acer Aspire 5315 Notebook
No display and no external display everything worked fine until i replaced the cdrw
  • Art Ellison
    Art Ellison May 11, 2010
    OK--just what happens when you boot the computer? What happens when you disconnect the new CD and start it?
    President:
  • 2,923 Answers
Connect first the external monitor in another computer to make sure that the monitor is still working.
You have to either switch or share the display to the external monitor. Locate the Fn button and the monitor icon in one of the function keys (from F1-F12) on your computer's keyboard.
Once you find it, press Fn + F# at the same time. (example: Fn + F8) and the display should transfer to the external monitor.
Posted on Jul 28, 2009
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
Image is blurred then goes off
Please connect a external display to this notebook and verify if the external display works fine. If the external display works fine, the you need to replace the display as it is defective.
Thanks and Regards,
Dr. Tony
Jul 23, 2011 | Computers & Internet
Just looking for a driver fro crwd 2400p cdplayer. The OS the driver is needed for is Windows XP. This peripheral is a PCMCIA cdrw dvd player and was bought from PSISM.com (they keep saying this item is...
Follow the steps given below
Connect the External CDRW to the PC and you should be able to find the green light glowing and CDRW should make some noise like spinning.
Press the Eject button the CDRW and It should open. Put in the Software disk that you have received from your PC manufacturer and it should display the contents on the PC Screen
If not, Click on START button - Click on My Computer - You should find the CDRW displayed in Drives Location.
Double click on it and it should display the CD Contents.
This indicated the CDRW is working.
Nov 09, 2010 | EXP Computer EXP CRWD 2400P (CRWD-2400P)...
When cdrw is inserted into d12 digital recorder msg display says no disc drive and after about 20mins whole thing freezes until cdrw is removed
try using a different type/brand of cdrw you may have a bad batch of cheap cdrw as for the freezing if this does not fix the problem try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 03, 2010 | Korg (KCDRW1X8X) CD-RW Burner
Dell Inspiron 1501
If the laptop keeps working, and you can use it on an external screen, then it is likely an hardware fault.
First perform a complete system recovery, like probably already instructed by the Dell support helpdesk. This will practically exclude the possibility of a driver or system problem.
If the problem is hardware , then you may have a faulty inverter board , a bad LCD display/LCD ribbon connection, or a faulty video adapter (integrated with motherboard).
If the problem is the inverter, then the screen will go dark, and the laptop will keep working on external display. This is probably your case.
If the problem is LCD display or ribbon cable, then the display will be blank with light on , and the laptop will keep working on external monitor.
Fault concerning video adapter usually cause the the system not to work at all, and it is uncommon under conditions described.
Sep 04, 2009 | Dell C3039 Inspiron 1100, 1150, 5100,...
Display has vertical white lines. Hook up a external flat screen and it works fine . Toshib Qosmio g25
this indicates you have a bad screen, and if you press around on the back (top) of the computer display the lines will disappear until you take your hands off the area effected, and the screen needs to be replaced.
Jul 12, 2009 | Toshiba Qosmio G25-AV513 Notebook
Western digital my book usb 2.0 connection is on and off
Perhaps the power supply (Typically 12 VDC, 2A) to your MyBook is flaky?
Mar 16, 2009 | Western Digital 500GB My Book World...
Startup display problem P100 PSPA3E
Hi, ok clearly for the symptom of what describes modal to his portable , I understand that the fault of his equipment comes from the card of video, which not this on board but it is separated, if the problem that he presents also happens for the VGA port and for the DVI port, this indicates that the problem that his equipment presents into in the system board.
Dec 06, 2008 | Toshiba Satellite P100 Notebook
Won't display photos from a CDRW
Check what type of file type the Kodak is creating, it may not be a JPG. If its not you would need to look in settings or check the manual to see how to change the camera so it saves the files as JPEG'S.
Or the long route compress them into JPEG'S on your PC.
Feb 16, 2008 | Philips DVP-3005 DVD Player
Asus CDRW
Sounds like the laser is burnt out. I would replace the drive.
Oct 11, 2006 | ASUS CDRW 52X32X52 CRW-5232AS BK RT...
Acer Aspire 5315 Notebook Logo
276 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
