Question about Baby Gear
Can't get sides to stay up (lock) on our Century fold n go lullaby center
I had the same problem until I found the manual and practiced a bit, When opening, it's important for the middle to still be in a high unlocked position - then they click right in place very easily. The sides won't go up if the center column is down too far first because the middle locks in place automatically and prevents movement of the sides.
When folding it, the floor lock has to be twisted fully in the unlock position and the center column back up in a high position for the sides to fold in (each side as 2 joints to disengage). Unlocking turns the center support column so that all the support tubing underneath can move. If the center column won't come up high, you don't have it unlocked yet.
Here's a Century Fold N Go instruction manual.
http://www.gracobaby.com/Instruction%20Manuals/archive/10765.pdf'
To look for different models
http://www.gracobaby.com/customerservice/productinstructions/Pages/default.aspx
Posted on Aug 17, 2009
How do you fold this thing up?
Remove the top part and push the button on the sides and the two ends will fold in
Apr 13, 2011 | Chicco 4in1 Lullaby Lx Playard Hazelwood...
I can't fold up my Cosco Play Yard 05028. Specifically I get all the sides unlocked but they won't fold up into their upright position (i.e., compact enough to get back into the carry bag.
Hi You have to remove the floorboard and pull up on the strap in the center of the floor before you do anything else, then you unlock the long rails followed by the short rails. If the lock won't release pull center strap higher and try again. Hope that helps!
Oct 06, 2010 | Toys
I can not get the sides to lock-in. What is your suggestion? My play pen is Century Fold-n-go TM Deluxe Care Center.
I think I may know how to solve your problem. I had a similar issue with the pack and play my mother-in-law gave me.
It seems to never work if you set the play pin up right and try to lock the sides up. Tug and pull all you like it just wont do it. I would suggest that you collapse it completely, then try to lock the sides, short first, while the system is either upside down or on its side. Then lock the longer sides.
This is what worked for me at least. I hope this helps. :)
Sep 27, 2010 | Toys
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
I've locked my trunks keys in the trunk. The car is a 1988 Buick Century. Is there a hidden latch to open the trunk, or do I have to find a locksmith?
You should have a trunk release inside your car. It will either be somewhere along the side of the driver's seat, or it will be along the bottom of the dash. If not, your seats may fold down so you can access the trunk
Aug 26, 2009 | 1998 Buick Century
Winnie the pooh travel cot from mothercare. cant get the sides to stay locked, they keep folding down when pushed to check if they are stable. need instructions. don't know actual name of product, but it...
hi there yes you need to pull the middle handle right up almost halfway high as cot then flip sides out they will automatically lock then close the handle x
May 09, 2009 | Baby Gear
I have a graco century pack n play crib that will not fold down
did you pull the center up before you pushed the buttons on the side? mine is tempermentale too. you must pull the tab inside on the bottom before even touching the sides. then try the longer sides first after the center pull and do the shortest sides last. if not contact graco they may be of assistance, or just take it back it may be defective.
Nov 10, 2008 | Graco Quattro Tour Travel System
Folding up Cosco play yard
you also need to hold one of the middle indicator tabs on the longer side..because if you don't do that it will not shut... and make sure the 2 legs go inside with the center of the play pen
Dec 03, 2007 | Cosco Beatrix Potter Playard Crib
Baby Gear Logo
1,020 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
