Question about Sony DVP-FX810 Portable DVD Player
I have a "line in" error - Sony DVP-FX810 Portable DVD Player
Should be a line in/line out switch on the player. flip it to line out.
Posted on Aug 21, 2009
What is error code E000110-0105 for a Canon imageRunner C4080 copier?
Hello Sir,
This error is about yellow laser unit:
Your error code translate:
E000110 = Polygon Error
0 1 0 5
1st line: Always 0
2nd line: Station where the error occurred (1: Y, 2: M, 3: C, 4: K)
3rd line: Main unit status when the error occurred (0: Activating, 2: BD control 1, 3: BD control 2, 4: Changing the speed, 3: Operating steadily)
4th line: Polygon control status (0: Suspension, 1: FG rotation, 2: BD control 1, 3: BD control 2, 4: BD Control 3, 5: BD control 4, 6: Phase locked)
In most cases you need to replace laser unit, but first, you need to check all the connections between electronic board and laser unit.
Best Regards,
Mar 27, 2015 | Canon Office Equipment & Supplies
E07, e08, e02, e15 error in canon mp258, pl. give meaning of error & solution
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Jun 15, 2011 | Office Equipment & Supplies
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
On line error
red line error problem
May 03, 2010 | Samsung ML 1610 Laser Printer
Problem faxing-error message
Error 388:
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Brother FAX 8360P comm.error
It could be line noise on the phone.., which allows phones to work ok, but causes problems with faxes. See this document from the brother website concerning comm.error:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000067/faq000167_000.html?reg=us&c=ca&lang=en&prod=fax2800_us&Cat=11
Would recommend having the phone company run a line check to make sure the phone line is clean of interference !
Jan 21, 2009 | Brother FAX-8360P Plain Paper Laser
Fax machine communication error 43 on kx-f750
communication error 43 is error of telephone line.there is some distarstion in telephone line.some noise in line .due to this it is facing problem.just clear ur line .or check with an other line.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
Xerox WC Pe16 ask for solution for Internal error false... line 226
INTERNAL ERROR - FALSE
POSITION: 0x4364c (276044)
SYSTEM: H6FW/xl_image
LINE: 495
VERSION: QPDL 1.40 11-14-2005
Jul 03, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Poor line condition error Brother intellifax 5750e
Poor line condition is an error referring to the phone line itself. Even though it may sound clear small amount of static confuse the fax machine and cause the error. Try using a new phone line. If that doesn't help I recommend getting a line filter from OfficeMax
Oct 11, 2007 | Office Equipment & Supplies
Sony DVP-FX810 Portable DVD Player Logo
95 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
