Back to:
Tags:
JVC TH-A30 System
Region
posted by art660 on Nov 22, 2007
is there any way to change my jvc th-a30 in a region free dvd player
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 18, 2007
Not Rated (0)
Half-Tool
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
Remove all power from the unit. Let it sit a few minuets. Plug it back into the wall outlet. This should resolve the problem.
Put the dvd into the unit that you were having problems with, and try and play it. If it works - everything is ok. If not - try repeating the process 2 to 3 more times. What is going on here is the Unit automatically assigned a regional list in its memory. Sometimes this happens during an AC power surge (noise) on the line. This can corrupt the macienes internal memory. Bypulling the plug you allow the internal circuitry (typically some capacitors) to discharge. After this the unit will re-set & the error will go away.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on region:
I don't want to Accept this solution
Can you Help with these Home Theater Systems problems?
JVC TH-A30 System
It looks that there is something bad with the laser of the...
JVC TH-A30 System
Tray will not open to accept a disc. It's on, push the...
JVC TH-A30 System
What is the code for this system. I want to operate it...
JVC TH-A30 System
In 2003 I bought a JVC TH-A30 and it played all regions...
JVC TH-A30 System
How can i code free my home theater JVC model th-a30?
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
