Question about Hoover Dishwashers
What is the rapid program used for in hoover HDW1400X used for, and do the dishes get 100%dry
2 Suggested Answers
COXY
  • 76 Answers
SOURCE: INDESIT D61D.i dont know in wich program dry the dishes
Probably programme 2 or B
Posted on Nov 27, 2007
I have a hoover dishwasher it works normally but it does not heat the water or dry dishes .
The heating element may have failed and will have to be replaced.
Feb 06, 2015 | Hoover Dishwashers
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
Our bread has not been rising, and so it comes out sort of hard and misshapen. We've been using the rapid course, and have been adjusting the amount of rapid rise yeast
The rapid rise will not produce as good a texture of bread as the normal full program. Never let the yeast come into contact with liquids or fats in the pan. It must stay dry.
Dec 15, 2010 | Breadman Pro Dual Bread Maker
Been having issues with my 625. I noticed in the diagnostic listing...boot recovery says 2.. What exactly does boot recovery mean in terms of problems with the receiver? Sounds to me like a harddrive...
If your receiver is going into boot recovery - this is a DOS based program- you will be better served by getting it replaced. On newly installed receivers this can occur as a result in the manufacturing process or re-manufacturing process and not cause further issues.
Thanks for using Fix Ya.com.
Oct 08, 2010 | DISH Network DVR-625 DTV Receiver /...
My Dishwasher has a rapid flashing light
I get the same problem with a pepeating beep warning. Only solution I've found is to switch it off using off button then switch it back on. It waits a few seconds then finishes the program and drains. The dishes still seem to be quite damp after. Hope this helps
Jul 12, 2010 | Hoover Dishwashers
HOOVER STEAN VAC 2 DEEP CLEANER
If you used any other cleaning solution other than Hoover, your Steam Cleaner will develop deposits in the turbine that drives the brushes. What happens is this:
Users pour other store bought brand cleaners in the reservoir to clean. Then they store the Hoover Steam Vac. While sitting in storage, the residue dries in the turbine and develops hard deposites, which ruins it. It will cost you about $100 to have the Hoover Store repair.
Cleaning Solution:
http://www.amazon.com/dp/B0002B8L26?smid=ATVPDKIKX0DER&tag=yahoo-kitchen-20&linkCode=asn
Oct 14, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Washing leaves spots
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you're using and adjusting your hot water heater's water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water. First you'll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, you can wash the glass with warm water and concentrated dishwasher detergent or use a high-phosphate detergent (such as Glass Magic) according to label directions. If film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature. See "Doesn't wash well," above. Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn't anything you can do to make it clear again. But you can avoid future etching by taking these steps: 1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don't use extra hot settings, such as "Power Scrub" and use "Energy Saver" dry cycle. 2) Adjust detergent amount. 3) Don't pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Dishwashers Logo
Top Hoover Dishwashers Experts
Jose Pino
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
