Question about Wittnauer Watches
I have a stainless steel wittnauer watch with chronograph and instead of being set on the :30 mark, it is set on the :01 mark on the stopwatch. i need it back to :30
  • Anonymous Mar 25, 2014
    the pullout dial retracts back into position when trying to set time
  • 2,334 Answers
Pull out crown and press and hold one of the pushers (depends on a movement model). Try till you see chrono hand moving and reset it by using correct pusher. Every time you try a different pusher - push crown in, then pull out and try again.
Rate me, please.
Posted on Jul 28, 2009
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
I lost the stainless steel bezel (back) to my Wittenauer. Is it possible to get a replacement ?
I think the only place you are likely to be able to get a replacement is from the manufacturer.
If you go to http://www.bulova.com/brands/wittnauer/wittnauer.aspx?brand=wittnauer and click on "dealer locator" you will be able to find your nearest dealer, who should be able to arrange for a replacement if it is possible to get one.
Good luck.
Feb 01, 2011 | Wittnauer 12B09 Wrist Watch
Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Feb 25, 2010 | Bulova Diamond Chronograph #96R31 Watch...
Swiss Legend Chronograph Stainless Steel Case- how to change the battery
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yours
Feb 24, 2010 | Swiss Legend Chronograph Stainless Steel...
On a Invicta Men's Off-Shore Russian Diver Quartz Chronograph Silver-tone Watch, the big min hand does not stop at the 12 clock position but instead stops 2 mins before the 12. It stops on the 62 instead...
It isn't a fault and can be adjusted. Follow this link and find out how to.... http://www.invictawatch.com/ Point at COLLECTIONS and click on INSTRUCTION MANUAL. If you don't know which one of movement makes you have, try both (RONDA first, then MIYOTA). When sorted with type of movement, check how to reset chronograph to 0 (zero).
Rate me, please.
Jan 12, 2010 | Invicta Off Shore Russian Diver Stainless...
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
I have a 1970 locman stainless steel chronograph. when i use the stop watch feature. the second hand does not return to the 12 o'clock position. instead it lands on the 3 o'clock mark. how do i re-set...
I don't know if this is the same for you, but on my watch I can pull the winder all the way out for the time setting and then I hit the start button for the chronograph and it will adjust the second hand. Hope this helps.
Thanks,
Eric Pederson
GVDCOPS
Jan 13, 2009 | Locman 1970 - Black Stainless Steel...
Which Wittnauer do I have ??
Ahh, you have one of those watches that have a long battery life. This watch has a lithium iodine battery, which power pace makers. Here's the name of it:
Wittnauer Longlife 6600 mens watch stainless steel watch.
Nov 23, 2008 | Wittnauer Laureate 12R12 Wrist Watch
Watches Logo
223 people viewed this question
Top Wittnauer Watches Experts
Jimmy Accardi
Are you a Wittnauer Watch Expert? Answer questions, earn points and help others
