What is a local Area connection? My laptop doesn't work, but my desktop does?
    Scholar:
  • 110 Answers
Local area connection is the wired network interface card on the computer. On a laptop you'll see the port on the side or back. If you have a internet cable conencted to the port you'll be able to access internet on a wired conenction. Most likely you are conencted wirelessly on the laptop so it shows the local area connection disconnected.
Posted on Jul 28, 2009
Local area connection doesn't have a valid ip configuration
It sounds like you found a solution elsewhere because you didn't reply to the three people who asked for more information.
You can close this problem if you wish to by saying YES.
Jun 14, 2012 | Computers & Internet
There's seems to be a short where the AC adapter goes into the Laptop. Loose parts in that area of the Laptop where the adapter goes in. It won't turn on. Maybe it's the battery.
Unfortunately, this is a frequent issue with laptops. Being moved around frequently can cause the AC Adapter to pull at the DC Jack on the laptop. If it is loose, it can mean there is a broken connection within the laptop. What you can try is powering the laptop on with it plugged in and the battery removed. If that doesn't work, I'd recommend going to your local Best Buy and picking up a universal AC Adapter. If that doesn't work, you can always return it, even if opened.
Aug 27, 2011 | Acer Aspire 5735 Notebook
Can't connect through a wifi hotspot
Check your firewall settings!Otherwise go down to the bottom right of your screen and you will see a picture of a computer with a plug to the left of it if its not there then click the up arrow near there to open the the task box and find it there.Double click or right click and open network sharing center.Now double click the link titled CHANGE ADAPTER SETTINGS,now you should see an app labeled LOCAL AREA CONNECTION, right click on that and click the enable button!If you dont see LOCAL AREA CONNECTION then you will have to create one where it says SETUP A NEW CONNECTION OR NETWORK,go throught the rigamaro and wala there you have you problem solved,if this doesn't work then call newegg.com 's support line!Hope this helps! -CB
Jul 03, 2011 | Acer Black AX3400G-U4802 Desktop PC with...
I WANT TO ESTABLISH A 'HOME NETWORK' BETWEEN MY PC AND WIRELESS LAPTOP. BOTH ARE WINDOWS HOME PREMIUM OPERATING SYSTEMS.
you must have wireless routers LAN (local area network)..you must also have an internet service provider... first you must connect the wireless lan routers to the modem ..then you must configure the routers ..you must follow the step step instruction in configuring the routers that will appear in your screen.....then test tha wireless local area network between your desktop and laptop...hope it will work for you...tnx.
May 30, 2011 | Computers & Internet
Cannot connect other devices to my router
You reset it to open, no encryption and it still didn't work? HMMM. You are able to get your PS3 online? but can't connect your laptop and desktop? Are you hard wiring the desktop to the router? or are you trying to connect it wirelessly? If you are configuring your router with either the laptop or desktop, make sure the IP settings on your connection manager are set to the correct domain under Local Area Connection Properties, like 192.168.1.226, or something similar. Login to the router with your admin credentials. Make sure in your configuration (as instructed in your manual) that you have the router time set correctly so the lease time for your devices aren't expired. Apply settings. After exiting your router configuration screen, go back to your connections manager, either wireless connection, or ethernet adapter in your network connections folder, and under the General tab of the Local Area Connection Properties, change the properties of your TCP/IP client back to "Obtain an IP Address Automatically." Click "Close" and your computer should show "Connected."
Feb 17, 2009 | Belkin (F5D5231-4) Router
Create a local area network
you can get a HP x175 printserver. (not expensive.) and connected it between the printer and the router. that way you don't have to have the desktop on all the time.
Dec 02, 2008 | Computers & Internet
How do i build a local area network in windows xp?
On the machine that the printer is connected to go to Start>Control Panel>Printer and Faxes>Right click the Printer that you want to Network and Left Click Sharing> Select the Option to Share the printer and Name it something that you wil remeber. On the Laptop go to printers and Faxes select add new printer and select Network Printer. And Choose the second option Put the Name of the Computer that the printer is connected to and then printer name. Example \\Desktop\HpPhotoSmart 8100. Also you will need to check to make sure that both machines are on the same Domain\Work Group. Go to Start>Control Panel >System>Computer Name Tab ( Here verify the Machines Name)> Join or Change Domain>Put the machines on the same Workgroup if they are not, Do the same on the laptop. To test this, on the laptop go to Start>run and type \\Desktop Name and you should see what is able to be shared. Walk thru the steps above to install the printer on the laptop and have the intall cd in the laptop to install the drivers and you should be good to go. I hope this is understandable. If not feel free to email me at smichael@phoenixschool.net and I will see if I can clarify this for you. Happy networking!
Although the internet connects on my PC my laptop won't connect via the router
check that your router is working that lan cable is working, and right click on network places in your laptop screen go to the properties and check there local area conection is enable if disable enable it and check your ip, if there is no local area conection you have to install the network adapter driver
Sep 27, 2008 | Computers & Internet
Router wont recognize the laptop computer we bought but the desktop works fine
if your trying to connect wireless check for the following.
make sure the wireless switch on the laptop is on, check if the laptop if can see or view an available networks.
if your trying to connect wired check for the following.
check the ip address on the laptop, including the dns make sure that the status of the local area connection is connected.
Sep 05, 2008 | Belkin Computers & Internet
Network Connection
First off, the 1394 connection is a firewire connetion. Firewire is a less popular and slower alternative to USB 2.0 connections. Disregard that in respect to your internet connection. Now in regards to your desktop internet connection.... -Go to the control panel, select network connections, then local area connection. -Right click and select properties -Under the general tab scroll down to Internet protocal (tcp/ip) Make sure the settings are set to automatically obtain an IP address. If they are and still are not working you can try to manually assign an IP address yourself. The laptops ip address might be something like 192.168.1.2 so whatever your laptop ip address is make the desktop 1 number higher in the last field (192.168.1.3 for example). Don't change any numbers other than the last field. You can find out the other information like subnet mask and default gateway by using the laptop. On the laptop go to the start menu, hit run. Then type in cmd, this will bring up a dos prompt. Then finally type IPCONFIG . Listed will be the laptops active internet connections and it's IP addresses. Copy over the subnet mask IP address and the default gateway address into the desktop and like in the previous step just manually assign the desktop a different IP address 1 number higher than the laptop. If the dns server's address isn't listed on the laptop a quick call to your dsl provider will solve that question.
Sep 29, 2007 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
