Question about GE 31GT740 31" TV
My tv turns itself on and then starts going thru the channel and when it is on will start changing channels?
  • ab6370 May 11, 2010
    try seeing if one of the buttons is stuck
Assuming your TV continuously changes channels on its own in the upward direction, I had the same problem with my GE 31GT740 TV and fixed myself. GE will give you the runaround and have you calling RCA who has no clue. The cure is simple but, you need someone to help you move the set around. Remove the rear cover by taking out all of the screws – obviously unplug the set first. Then remove the large circuit board by taking the two screws out from the underside. The TV will need to be laid down on the screen side so have a large pillow or blanket laid out. The main circuit board has two side stops that hold it in and then pry it a little. The entire board slides out and you can set it aside. Now, remove the front switch panel assy by depressing the two side stops. Then the circuit board behind the switches can now be removed from the assy. The third button in from the center is the ‘up channel button’. Pry off the small switch soldered to the board behind the ‘up channel button’. Reassemble and the problem will be fixed. In other words, the ‘up channel’ button on the TV set has gone bad.
Posted on Nov 08, 2009
Magnavox TV turns itself on and changes channels
channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
Dec 14, 2015 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Cuts on and off and changes channels
change your tv chanel program button or its problem in programing devise or video frequency
Aug 28, 2009 | GE 31GT740 31" TV
Channels and inputs change by themselves
sometimes unplugging it from the wall for a few minutes or even overnight can fix weird issues like this.
also, there is a small chance that a new channel scan thru the menu system might refresh the channel memory and clear it up.
this series of TV's are prone to a lot of problems tho, so it will likely soon be time to start shopping around.
Feb 11, 2009 | RCA F38310 38" TV
Tv changes channels when turned on.
Be sure your remote hasn't got a button stuck down which is changing channels. If not, take the batteries out of the remote. If this stops the channel changing there is probably some conductve material stuck across the circuit board
inside the remote. If this is the case you have to check inside the remote by openning it up.
Jan 28, 2009 | JVC AV-27530 27" TV
Problem with JVC AV-27530 27" TV programing itself...goes through the channels and will not stop.
THESE SETS ARE BAD ABOUT THE KEYS ON THE KEYBOARD STICKING--I POSTED MAYBE A CURE FOR THIS ...READ IT TUNICA
Sep 14, 2008 | JVC AV-27530 27" TV
GE 31GT740
You may have a sticking button on your front control panel. Sometimes they become intermittent and cause crazy things to happen. I've found this in RCA tv's and GE's are made by the same manufacture. Stargazer
Apr 23, 2007 | GE 31GT740 31" TV
SPECIFIC FIX FOR GE 32GT660
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Nov 21, 2006 | GE 32GT660 32" TV
GE 31GT740 31" TV Logo
208 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
