SOURCE: samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
SOURCE: 1998 Dodge Durango no heat when using heater.
BLEND DOOR STUCK OR BROKEN. NEEDS TO REMOVE DASH AND HEATER/EVAP CORE BOS TO REPAIR REPLACE.
SOURCE: QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
SOURCE: when filling bathtub or running two showers, water heater howls
it could be the fact thath the water comming in is what the problem is,, on a well system the water is extra cold and the unit is working hard and with sand aso comming in it makes it harder to keep the temp up on the water,,, flush the tank, put hose on it and open the drin valve with a hose on it turn the cold water on and let it flow till the water comes out clear usually about 5 min,,, get all the sand out and other debris and try it
