Question about GE Refrigerators
THE COMP ON MY REFRIGERATOR WONT AND HAS NO VOLTAGE GOING TO IT
  • Ken Bledsoe May 11, 2010
    Do you have volt meter
  • 286 Answers
Does the fan run? If not then check the thermostat
Posted on Jul 29, 2009
Kenmore Elite Refrigerator. Model #795.72093.310. It will not cool with no alarm.
how do the lines feel to the compressor. if they are room temp, you may have a leaking sealed system, or refrigerant leak
Dec 18, 2016 | Kenmore Refrigerators
Low voltage at compressor!
My parts lookup too has no images available for you refrig but i believe it to be a GE Profile with a fresh food fan (and air duct down the center of the fresh food side). All fan motors are 12vdc and run off the Lowvoltage side of motherboard. i assume you are checking voltage to comp from motherboard? How did you check relay?? Have you axcessed motherboard?? On the top of (I say top-- i belive its mounted horiz on yours but all the small wires are on the right) is all the low voltage fan motor, damper, control wiring On the bottom (or the left) side of the motherboard is the larger line voltage wiring. The connector with 3 wires is labeled def -- comp---line it should be blue. Try jumping L1 to comp. ((Just so ya know Def will energize the def heater regardless of compartment temp it does have a bimetal but it only a safety set at 100deg in case relay on board welds shut---it monitor evap compartment, frz, fresh food, (two seperate in FF) in your model))
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
I have a asus striker extreme that shutoff by itself
did you check already the switch mode power supply unit of your pc? might drop the voltage or need to upgrade with higher wattage.
Jul 04, 2012 | Computers & Internet
My kitchenaid ksrg25fkss refigerator supera wont get cold
freon. dirty coils under refrig. fan motor by comp. not working. make sure first of all comp. is running if not make sure freezer fan is. if that the case you need a relay starter overload or a compressor.
Apr 01, 2012 | KitchenAid Refrigerators
We experienced some bad weather with rolling black outs and now out Fridgidaire FRS26R4A is not cooling, is there such a thing as a reset button on refrigerators like garbage disposals? Help!
it is possible u got some surge voltage or low voltage and that could fry your compressor.. your fans could be running but no comp. you might check the start relay on the comp. ok.
Feb 11, 2011 | Frigidaire FRS26R4A Side by Side...
Marine unit will run but not cool or make ice
if it doesnot get cold it wont make ice. u need to check to see if comp. is really running. might have a bad relay on comp. ok
Feb 11, 2011 | U-Line Refrigerator Ice Maker
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
It wont cool
if the compressor is running your ref. should be getting cold.their is a defrost timer but when it is in defrost the compressor shuts off.I think you do have a leak.
Mar 20, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
No cooling on eather side
No, white to com, black to the run terminal, and to the start through the capacitor. I suggest you also have a 15-amp fuse or breaker in the line for protection. Given that you say the relay, cutout, and cap check out, and you say there is continuity through the compressor, I have to think that there is a high-resistance connection in the circuit that feeds the compressor. Suspect bad connection at the thermostat or the defrost timer. Be careful, and work with one hand behind you back so you do not receive a dangerous shock.
Dec 18, 2008 | Kenmore 53642 / 53644 Side by Side...
GE side by side problem
You will have to make some line and low voltage tests at the motherboard to diagnose this further. Start by removing axcess panel to motherboard on back of refrig. Locate 3 PIN blu connector on bottom of board. Wires are labeled Comp, Def, Line. Jump Line to Def At connector. Look at heater at bottom of evap coil for glowing red heat. If no heat heater is bad, if it does heat time to go to the next step!
Dec 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
