Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have an early 90's cub cadet rider and it was over filled with oil. Now it smokes and blows oil out the exhaust. Could over filling it cause this? If not are there any common causes of blowing oil
  • Blackfoot17 May 11, 2010
    is there a leak in the oil line?
    President:
  • 1,273 Answers
Yes, over filling can cause this. The fix for this is to put the oil level back to normal, and run your machine normally, until the oil residue burns back off. Some "side effects" may be fouling spark plugs and occasionally residue build up in the muffler, so, keep this in mind. Normally, though, everything goes back to normal. It's better to run the machine for a while than starting and stopping it, to allow the machine to get up to operating temperature and clean out the exhaust system.
Best regards, --W/D-- please feel free to rate this solution.
Posted on Jul 30, 2009
    Novelist:
  • 133 Answers
My friend had a White tractor that was blowing oil out the exhaust and smoking. I replaced the valves and it runs like a champ.
Posted on Jul 29, 2009
Cub cadet LTX1046VT white smoke and gas coming from exhaust when first started.
Carb. Needs needle valve or float repair to keep fuel from flooding. If it does not have shut off valve in fuel line from tank to carb. Install one and ALWAYS close when storing between mowing. .
Sep 08, 2017 | Cub Cadet Garden
Why is my cub cadet xt1 blowing black smoke cleaned air filter made sure oil level is correct.still blows black smoke
Make sure that at full throttle the chock is not being used. Black smoke coming out of the exhaust of gasoline engine is a sign of a rich fuel mixture (too much fuel, not enough air). A brief puff of black smoke may be visible during hard acceleration when the fuel mixture goes momentarily rich, but under normal running conditions and idling the exhaust should be transparent. If black smoke is visible all the time and the inside of the muffler is coated with heavy black carbon deposits, it would tell you the engine has a rich fuel condition.
On engine, a rich fuel condition and black smoke can be caused by a stuck or maladjusted choke, a leaky metal or hollow plastic float inside the carburetor fuel bowl, or a fuel saturated foam plastic float, or an incorrectly adjusted float (set too low). A trestricted fuel filter may also contribute to a rich fuel mixture.
Jul 04, 2017 | Cub Cadet Garden
Cub cadet rider, white smoke, oil on spark plugs........help!!
Not to panic... the oil should burn off. It will just be a little embarrassing to have all that smell and white smoke until it does! However, the real question is, how did oil get on the spark plugs in the first place? If you spilled some oil on it, don't worry. If you left the oil filler open, make sure you check your oil level and close it. If you overfilled the oil level in your mower, drain some of the oil out.
May 03, 2015 | Cub Cadet Garden
CARBURETOR LEAKING OIL AND SMOKING
IT is likely that the carb is leaking fuel and filling the crankcase with fuel. Causing excessive crankcase pressure forcing oil into airbox through the crankcase vent. Check your crankcase for fuel and/ or being overfilled. If fuel is present fix the carb first, then drain and refill crankcase. After all is fixed run the unit outside for a few minutes and let it burn off excess smoke.
Sep 02, 2014 | Cub Cadet 46" Lawnmower Deck Drive Belt...
What caused 19 horse Kohler to belch white smoke
white smoke fuel blue black white smoke oil over fill oil will cause it getting to much fuel will cause it check carberator check oil
Sep 02, 2014 | Cub Cadet Garden
Gas Blowing Out of Exhaust
Hi Haley
Here are a few suggestions
May 02, 2013 | Cub Cadet Garden
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
My Cub Cadet oil light was on it read 100 hours
Yes, you overfilled it with oil. Drain the oil and fill to the correct level. If you are not sure how much to put in, add small amounts until the dipstick shows a full reading.
Jun 15, 2009 | Garden
Lots of smoke coming out of Cub Cadet 2146 muffler
Check the dip stick to see if you over filled it.. You shouldn't have oil above the top line... If you did over fill it remove the dip stick and tilt the mower to the exhaust side to drain on the excess oil out of the dip stick tube...
If it's not over filled with oil the engine more then likely shot and it's time for a new mower..
May 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
723 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
