But only I stumbled on bad situation on Acrobat Reader DC. Today one of my working .pdf documents hasn't opened. I tried to open it many times. Now I don't have any resolutions for this.
SOURCE: adobe acrobat reader is not opening...
if you have the original install disk for adobe acrobat reader the uninstall the program then power down then re-install the program
SOURCE: unable to download pdf file
Uninstall all Adobe software what ever version you have, than go to start>search>all files and folders, select local hard drive if it is not, than click more advanced options, select first three things in the list and than type adobe in All or parts of the file name. When it finds folders and files select them all and press DELETE. Than empty your Recycle Bean and restart your computer once it is up download new Adobe installation file and install it again. I know that this is pain but you will have to get rid of all damaged files used by adobe reader.
SOURCE: Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
SOURCE: Acrobat 7.1 shuts down after opening
Installing later version of Adobe Acrobat is sometime creating compatibility issue with previous installed Adobe Acrobat Pro.
Make a deep search for your condition on Adobe KB: for similar problem I had to Reinstall Adobe Pro AFTER an update of Reader free Sw.
Check this entry
SOURCE: Failed export to a word document from Adobe Acrobat 9 professiona
I am not sure that I would calssify this as a real solution but I had the same issue on an XP machine running Word 2003 (with the 2007 compatibility module).
When I took the exported document to a Vista machine with Word 2007, it opened it fine.
Of course, I think it converted or imported it to 2007 format.
The Vista machine does have more memory in it and a better processor but not that much more/better.
So, don't despair, there probably IS a way to read it and edit it, but possibly not with the machine you are on (sorry).
I am still researching to see if I can find a work around for the XP machine.
