Question about Logitech Cordless MX Duo 967300-0403 Keyboard
Random Freezes and typing of re15.2 when clicking the v key. Opening countless windows.
Beeps after turning it on
First i will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues
After that start pc in safe mode, normally Pressing F8 key when windows starts up
Click start>Run.. Type msconfig>enter>Start Up. Uncheck the boxes for the programs that you think you may not use often
Open task manager and close any unnecessary processes running in background
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files, fix registry and windows errors.
Hopefully It will help you
Jul 01, 2013 | Dell Inspiron Mini 10 Notebook
LAPTOP KEYBOARD AND CURSUR FREEZES
you can try to remove the keyboard and reseat the ribbon cable, or you can go to device manager (hit windows key + r key and type devmgmt.msc) and uninstall the keyboard (right click and click uninstall) then restart the pc, it will reinstall the drivers upon boot. see if that helps!
Feb 22, 2012 | Acer Computers & Internet
Acer one 751h freezes
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
computer restarting Click Start and Open the Control Panel 2. Go to System and Maintenance, Click on System. 3. Select Advanced System Settings and choose Advance tab. 4. Under Startup and Recovery, click on Settings. 5. Under System failure uncheck Automatically restart. Another cause for random reboots is that the computers processor is getting too hot. To check this, enter the computers bios during boot (usually by pressing Delete, F1 or F10 when the computer just starts) and there will be an option about the computers temperature (often under "PC Health"). U can have registry error.Run a registry cleaner reg in out .
Sep 21, 2010 | Acer Aspire One PC Notebook
Jumping cursor on windows7
change ur driver, update os, and install antivirus, download reginout intel partner may fix it
Sep 03, 2010 | Sony VAIO Notebook
How to get the windows vista product keys...
To lessen the pain of browsing countless links that will only give you advertisements,malware,headaches,and posers who will give you sermons that using this product key is illegal or saying publishing product keys are not appropriate,well this is different.type this universal product key YFKBB-PQJJV-G996G-VWGXY-2V3X8.
And for your need to activate windows vista,download clonysoft one click vista activator.To pass WGA checks and make your copy of windows legal,you can use Resource hacker(a free utility program) and download antiwpa.dll and add this to your system registry.
Have fun and enjoy your new machine!
Aug 01, 2010 | Microsoft Windows Vista Ultimate Edition
Have set up a two player game and when ready to start it freezes
If it freezes in the same place, its the game, if it freezes in random places, then its a problem with the gpu, the console will need opening and new heatsink compound applying to the chip, this is basically the same fix as rrod, so there are plenty of free guides on youtube if you want to tackle this yourself.
Mar 10, 2010 | Microsoft Xbox 360 Console
I have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
. Open Start >> Run or press Window Key + r , this will open the run prompt.
2. Type “regedit” ( without quotes )and press Enter.
3. Navigate to key
HKEY_CLASSES_ROOT\Directory\shell
4. Double the registry key named Default and set the value to none.
This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
If search opens when you double click on any windows drive, then try this
1. Open Start >> Run or press Window key + r
2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
I hope this will help to fix the trouble.
Jan 17, 2009 | Microsoft Windows XP Home Edition
Norton 360 Invalid Product Key
go to the command prompt and type the regedit
>left click HKEY_Local_Machine>software>symantec>ccpdlcdelete the kstore>now try to activate the product
Dec 31, 2008 | Symantec Norton AntiVirus 2004 - (Open...
Unable To Open Drives Through Right-Click
There is one option you may not know about. This is normally one of the tricks that the Tech help desk ppl at Microsoft and such often use. It could be due to a corrupt registry key or incomplete Windows file. I also Use Windows XP and this has saved me countless times. Click on the start button on the bottom left of your screen, then click on the icon that says Run, in the dialog box type sfc scannow. This will prompt your version of Windows to scan all critical files for errors and fix them as needed. Make sure to have your windows CD handy as it will be needed by this tool to make changes to the Operating system core files and registry keys.
May 20, 2008 | Microsoft Windows XP Professional With...
Logitech Cordless MX Duo 967300-0403 Keyboard Logo
261 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
