Ok the wii cursor worked perfectly until after i loaded the new game i got. i went to the games menu and the cursor just died! i hit the remote a few times and the cursor came up for about a half-of-a-second then went again. what should i do?
Try to re-sync the controller to the Wii by lifting the flap on the front of the Wii and pressing the red button, there is a red button on the Wii-mote too under the battery cover so press that too.Try to re-sync the controller to the Wii by lifting the flap on the front of the Wii and pressing the red button, there is a red button on the Wii-mote too under the battery cover so press that too.
Does your controller still sync with the Wii or is it only the cursor that is not resopnding?Does your controller still sync with the Wii or is it only the cursor that is not resopnding?
You can't post conmments that contain an email address.
Check to make sure the sensor bar is securely plugged in. My sensor bar quit working because the wire got damaged and I just went and bought a wireless one and rechargeable batteries. Mostly the sensor bar is only used for the menu and any games that have target shooting like billiards. You can bowl, play baseball, tennis, and golf without it on Wii Sports. I hardly ever use my sensor bar since discovering that it isn't used as much as I thought. We just turn it on load the game and shut it off and everything works perfectly on most games.
its ok dont worrie wash the game disk a little in water then put liquawd soap on it then rub the soap around the whole disk after that wash with water untill all the soap is gone then dry the disk then try playing it again :) hope this is good luck bye
make sure your wii controller is properly configured, go to your wii system settings and make sure all the settings are correct and your controller is properly configured. Your proximity to tho sensor bar also plays a role in this, dont get too close :)
Cursor not appearing Please note that our experience shows that this troubleshooting is best performed using only one (1) Wii Remote at a time.
Some games do not use the cursor feature of the Wii Remote; Make
sure the game you are attempting to play uses the cursor by reading
the game's instruction manual. You can also exit out of the game
to return to the Channel Menu and use the Wii Remote to see the
cursor. If the cursor still does not appear, continue with the
steps below.
Trying to use multiple Wii Remotes in the Mii
Channel or Photo Channel? These Channels only allow the Wii
Remote designated as "Player
1" to function.
Verify that the Wii Remote's pointer lens is free of obstructions
and contamination (stickers, heavy smudges, etc.). The pointer
lens is the tinted rectangle at the end of the Wii Remote.
Check the battery power level by turning off the Wii console, then
opening the battery cover of the Wii Remote. Press and release the red "SYNC" button
to check battery strength. The number of lights flashing indicates the Wii
Remote's battery strength. Four flashing lights indicates full strength.
Our experience has shown that as your battery strength decreases to one (1)
or less lights flashing, the cursor may not appear. For troubleshooting,
if possible, try using fresh batteries so that all four lights illuminate.
For guidelines on using batteries, please click
here.
If after
inserting brand new batteries, you are still seeing less than all four LEDs
flash, then your Wii Remote will need to be repaired. Please click
here for repair information.
Is the Wii Remote properly synced?
Press the POWER button on the Wii Remote to see if the Wii console powers
on.
If it does, the Wii Remote is synced with the system. Please skip to the
next section.
If the Wii Remote will not sync, there is likely a problem with the Wii
Remote. Please click here for
repair information.
If the Wii Remote will sync and the cursor still does not appear, try
another Wii Remote if possible.
If at least one Wii Remote is working, there
is likely a problem with the first Wii Remote and it will need to be repaired.
repair information.
If you have only one Wii Remote, or none that are working, please continue
troubleshooting.
Make sure that the Wii Remote is being used between 3' and 10' directly
in front of the TV and that there are no bright light sources affecting
the Wii Remote's operation (review Game
Play Guidelines for more information), and
that the Sensor Bar is placed properly (see Sensor
Bar setup).
Check the cord on the Sensor Bar for any frayed wires
or kinks, and verify that the Sensor Bar is free of obstructions.
Check the button functionality, and that the Sensor Bar is operating correctly,
by accessing the Wii Main Menu. Use the "+" and "-" buttons to scroll side-to-side
through the Wii Channel screens.
If you are able to scroll with the "+" and "-" buttons, but the cursor is
not appearing, then there is likely a problem with the Sensor Bar. Please click
here for additional Sensor Bar information.
If there is no response, there is likely a problem with the Wii Remote. Please click
i did right before the game.
i did
