Question about Video Game Consoles & Games
Ps3 does not read discs
When i put a disc in my ps3 the green light flashes for a few seconds and the bluray drive makes noise for a little bit. But after that, there is nothing, there is no green light, just the red light indicating power on the right side. It does not read any kind of disc, and i was wondering if there was any way to fix it without replacing the bluray drive-if thats my problem
  • 6,784 Answers
HI, this is an optics failuer code. this will usually happen in units of this nature due to high levels of usage. the optical assembly will become unstable at times in this case, allowing the alignment to shift and cuase spin motor failuers. the lens assembly will burn out as well. all of these componets are housed within the drive. It is nessecery to replace the entire drive when a major failre occurs as is in this situation here.
You can also just replace the optical assmebly as well, althouhg this is nto recommended when the is misalaignded(noise when trying to play the disk)
i recommed replacing the Drive. this will fix thsi issue.
Posted on Jul 28, 2009
  • Michael Masters
    Michael Masters Jul 28, 2009
    Please excuse those major typo's.
    Thx:)
  • 30 Answers
Try using a cleaning disc..if this does not work ..you can replace the drive or the optical pick or blu-ray laser..I have repaired several ps3's and replaced the drives..
Why My Ps3 Keeps Ejecting BD?
This is a bad drive. I'd replace it immediately before trying anymore disks lest it damage the disks. Usually this occurs when there is a read error. It is also possible there is a disk stuck in the drive, jammed inside, the sensors, sensing the second disk automatically ejects the one you put in. Either way remove the drive and replace it with a PS3 replacement drive. (Note a way to test if it's a bad bluray lense is to stick a DVD in the drive. If it accepts the DVD and plays, then it can only read the DVDs and not the blu ray disks. If this is the case you've blown the blu ray laser, it still needs to be replaced.) If all else fails take it to a tech place and have them diagnose the problem.
Jul 29, 2014 | Sony Playstation 3 (PS3) Console
My playstation 3 won't play blueray, but plays games. Help
Hi kimsotir
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If its not reading ps3 game disc's or bluray disc you need a new bluray drive which are $90 on ebay very easy to replace..
If it won't read bluray disc ONLY well this could be because of the region of the bluray disc check that its not regioned to another country because ps3 is regioned locked...
If you need more help please let me know
Jan 26, 2011 | Sony Playstation 3 (PS3) Console
PS3 not reading disc when placed into console, When i put a disc in it doest read it but the blue light is on?
Hi there you need to purchase a new bluray drive which is about $90 on ebay very easy to install yourself google utube to find the videos on how to remove the old and replace with the new drive..Warning make sure you find the right bluray drive for your model ps3 cheers nikki
Jan 15, 2011 | Sony PlayStation® 3 (80GB) Console
Ps3 won't read discs
PS3 won't read discs you need to fix, clean or replace the bluray drive. Learn the step-by-step way to fix your PS3 and bluray drive is best way for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide : http://bit.ly/fixya-ps3
Oct 03, 2010 | Sony Playstation 3 (40 GB) Console
I got a PS3 from a friend who Told me if I could fix it I could keep it. The Initial problem was that it was not getting any power. I fixed that problem with a new power supply. It now turns on, all the...
looks like they took the drive apart when a disc was inserted and put the drive back together in disc in mode
there are 2 little white pedals that pop up when its in "disc in" mode the only way to fix it is to take the drive apart and manually move it to "disc ejected" mode
to do that, when the drive is apart you have to take of the little peice with the cd guide wheels then open the wheels and you will see a gap in the middle of where the little metal bars open up and the little white pedals fit through then just hit eject and they should lower now. put the drive back together and test it b4 you put the whole system back together.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not read discs
you can try to clean the laser and see if you are lucky enough to have that fix it. but usually it means your laser is shot and needs replaced. the laser is pretty pricey but it is pretty simple to replace.
Jul 29, 2009 | Video Game Consoles & Games
PS3 wont read any games, dvds or cds
I have the same problem. My PS3 stopped reading any bluray discs. The spinning circle in the top right corner will come on for a few seconds when a disc is inserted, but then nothing. I found a work-around to get it to read discs though. You have to have a bluray disc in the drive (game or movie) and start a downloaded game or Playstation Home. Once the game or Home loads, hit the PS button on the controller. The crossbar menu will pull up and you will notice the disc icon will (magically) pop up. Click the quit game icon. Once you are out of the downloaded game or Home the disc icon will still be there. You can then load the game or disc. The icon will remain there until you eject the disc, so you will have to repeat this every time you want to load a game. Although this is a workaround to prevent Sony from gouging you for $150+, this is still not a fix. A fix would be for Sony to admit they have a money making firmware problem and fix it. This fix will only work if you don't have an actual hardware failure (which I apparently don't). I think a class action lawsuit is in order for everyone that has this problem and especially for those who have shelled out the money to fix something that is firmware related. I'm sure Sony will only fix the firmware to make this workaround not work anymore so as not to lose their little cash flow scheme.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
Ps3 is not reading my discs
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise it goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 27, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Blu Ray drive not working
Hi my name is Juan and the problem you got is with the bluray laser lens they have stopped reading games you can check this out put a cd on your ps3 and at the same time place your ear on top cover and will heard 3 clicking noises of the laser but make no noise because this clicking noise is so fine that you need to make no noise i goes click click click you will hear it but make sure you put your ear on top cover at the same time you insert the disk it takes about 3 -4 seconds for the clinking noise after you have insert the cd some lasers they do try to read and they make the disk to spin off and on some they do make the disk to spin normally but nothing happen and the solution is to replace the laser lens I am a ebay trusted power seller and I can get you one if you want to
Mar 16, 2009 | Sony PlayStation 3 40GB System
Video Game Consoles & Games Logo
82 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
