Question about Coby DVD-224 DVD Player
Remote has failed to work. It's not the batteries.
Every button I push on the remote has the same effect as the "enter" button. Sometimes it will start to work again for a short while, but then quit again. I put new batteries in it.
    Problem Solver:
  • 8 Answers
It is possible that you spilled something on your remote which has caused it to fail or it is possible that the remote is just broken. If you have the skills to take it apart and see if there is a problem inside, then go for it. Otherwise you can order a new remote control from a site like www.newremotecontrol.com
Posted on Jul 28, 2009
How do I reset remote keypad code
Depending on the particular opener you have.. sometimes you press the turn light on button on the wall switch as you press and hold the door open button on the remote. Then it will reset itself and work. Some there is a learn button on the opener motor and you push this while pushing the button on the remote to get them both to sync.
Sep 27, 2014 | Building Materials
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
My remote wont work...the batteries when dead...changed them out and now when you try to use the remote...pushing any of the buttons it says"remote 2" on my dvd player entertainment system
It could be because when you replaced the batteries in the remote, it defaulted back to command mode 1 (DVD 1/MODE 1/REMOTE 1) so the transmitter on the remote no longer matches the unit - you could try pressing and holding both the [2] button and the [ENTER/OK] buttons on the remote for more than 5 seconds, then releasing. Sometimes with Panasonic remote units, whenever the batteries are replaced, the remote defaults back to the original mode. (mode 1); therefore the user needs to recode the remote to match the command of the receiving unit.
Simple enough to try, and costs nothing, except a minute or so of your time. This suggestion should be mentioned in the operation manual for your model system.
Jul 05, 2011 | Panasonic Televison & Video
Remote often fails to unlock the doors on my 2006 Buick Lacrosse. Seems to work better from farther away.
  • I HAVE HAD SIMILAR ISSUES WITH THE KEY FOB, OR "REMOTE" . UPON FURTHER INVESTIGATION, I OPENED UP THE REMOTE AND FOUND THAT THE THIN, SHINY METAL FRAME ENCLOSING AND CRADLING THE COIN-LIKE BATTERY (CR2025) HAD BEEN SEPARATED FROM THE SOLDER POINTS ON THE SILICON CHIP.
  • I ALSO DISCOVERED THAT ON THE REVERSE SIDE OF THE CHIP (BUTTONS AND RUBBER COVERING SIDE) THAT THERE WAS DIRT, DEBRIS, AND OTHER GUNK WHICH WILL DEFINITELY SHORT CIRCUIT, CAUSING YOUR REMOTE'S BATTERY TO BE DISCHARGED OR MISFIRE. THIS IS BEST OBSERVED WHEN YOU EXPERIENCE A "STICKY" BUTTON EFFECT ONCE THE "LOCK" BUTTON IS DEPRESSED ONCE, BUT THE CAR FEED BACK SUGGESTS 2 PUSHES OF THE REMOTE WERE DETECTED. ANOTHER EXAMPLE: I COULD HAVE SWORN I PUSHED "UNLOCK" TWICE (UNLOCKING REAR DOORS )ON THE FOB/REMOTE BUT ONCE I GET TO THE CAR, DOOR IS STILL LOCKED! WTF.
SOLUTION:
KEEP KEY FOB / REMOTE CLEAN, REPAIR/REPLACE BROKEN BATTERY +/- CONNECTIONS IN THE REMOTE, REPLACE LITHIUM BATTERY
Mar 15, 2011 | 2006 Buick LaCrosse
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
3 1/2 year old LG 42" LCD both Comcast Remote and
hi,
First of all check the remotes. You can easily check the remote is it working or not. Just point the remote to a digital cameras or a mobile camera and press any button . If the remote is functioning then you can see a white light blinking.
If the remote is working , then the IR receiver of your TV have some problem. you can find the IR receiver it the frond pannel pcb of your tv. i have added a picture of ir receiver. will help you to find out the same. if you need any more assistance feel free to contact me through fixya.
ok
images?q=tbn:and9gcs9kozrmmq6yap5xxawzkgmhck8whgxps07kojwikmztnl_rpvcx8cq1g
Feb 20, 2011 | LG 42LC2D 42 in. LCD HDTV
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
I hve purchased panasonic split a.c. b4 1 month only, mi remote senson is not working properly, i mean when i push mi remote button, its effect does not come in mi indoor unit sensor.
Ok, there are a few things to check.
1. Batteries on the remote.
2. Reset remote - switch sometimes in battery compartment and sometimes behind cover, need to press with sharp nib or pen.
3. Check on indoor unit that remote has been selected on the manual/auto switch, located under the cover on right hand side.
4. Remove indoor unit cover complete, (three screws behind the louvers and one on the electrical cover). Change the remote sensor board.
Mar 10, 2009 | Panasonic Heating & Cooling
Coby DVD-224 DVD Player Logo
267 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
