Question about Acer Aspire 4520-5582 Notebook
Unable to access Window Vista
Unable to access Windows Vista, I purchased the system recovery disks from Acer. When I tried to run them, I get to the 2nd in the 1 0f 2 set, and get the error message, "Recovery 32, Type Mismatch". So, I downloaded and burned the iso file "initialHDD" that tech support suggested, ran it then it said it was okay to run the system recovery disks and the same thing is still happening.......been working on this all day and am in the same place I started.......UGH! Somebody please help me........
  • lindylou961 Jul 29, 2009
    We were instructed by acer to download InitialHDD and burn it on a bootable disk?? So, searched around for the info to burn it and downloaded imgBurn program to burn iso image file, and burned the disk with it. Ran it and it said that it was completely erasing the hard drive, when it was finished it said it was okay to run the system recovery disks we purchased from acer, after running the first disk and being told to insert the second an error message comes up: "Recovery 32, Type Mismatch" and can't get past that.......any suggestions or links to info for this would be greatly appreciated!! I'm on the verge of losing what little mind I have left! Thank you so much for your help!
    trying to get past error message: "recovery 32, Type Mismatch" in order to proceed with running the windows vista system recovery disks, been at it alllllllll day.......pleeeeeeze help me, somebody!
    President:
  • 2,559 Answers
The problem is the disk is looking for a partion on the hard drive that is no longer there,the only way to fix this is to get an OEM version of vista and reinstall
Posted on Jul 29, 2009
    President:
  • 1,996 Answers
See this possibly helpful post..
http://forum.notebookreview.com/showthread.php?t=218094
Search 'recovery install Vista' on google for many more similar Acer posts....Here is one set of detailed instructions, with an explanation of how to correctly partition the hard drive.
See this link for basic Vista recovery options and link to their explanation. This tutorial for Vista startup repair.
I hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 28, 2009
  • efs_perpends
    efs_perpends Jul 29, 2009
    Please see this other post about your problem.....click here
    Is your system a 32 bit or 64 bit processor? (see here)
    I found this link but don't know how accurate the posting is...
    If there is more than one partition on the drive, make sure the partition you are installing to is formatted. (see here)
My acer aspire 5515 laptop system error window show when I try to boot. Hiw do I fix it?
so what i guess its giving mbr not found and its not booting , the solution is you need to have the windows operating system disk and then when your acer laptop starts to boot click on f8 then click on repair windows then after that you will see 3 option click on the third it will say repair cmd then type as what is given below
Click on the "Repair Your Computer" option to gain access to the System Recovery window. Now choose "Command Prompt" to run the Bootsect.exe utility. Bootsect is located inside the boot folder so change your directory to boot. Now run "bootsect /nt60 C:\" (without quotes) if you had Windows 7 initially installed in the C partition. Alternatively, you can run "bootsect /nt60 SYS" or "bootsect /nt60 ALL" (without quotes) to repair the system partition or all partitions. Eject the DVD and restart your computer. Your computer should now boot Windows 7 again.
Read more: How to Repair the MBR on Windows 7 ' eHow.com http://www.ehow.com/how_4836283_repair-mbr-windows.html#ixzz2CY96TyX0
Nov 18, 2012 | Acer Computers & Internet
Recdisc 64
What the software did you use to create reset disk to reset windows password?
As I know, a tool called Windows Password Reset allwo to create a reset disk easily and safely.
You can download from http://www.windowspasswordreset.net and have a try.
May 27, 2012 | Microsoft Windows Vista Home Premium Full...
I accidently switched off my mains before the system had completely shut down. As a result I'm unable to boot up, tried several times from all angles.\r\n\r\nGetting a message to the effect: The...
Acer Process 4/12 eRecovery Management indicates that the recovery process never finished - you will have to run it all over again.
As for MS Office , it came as a one month trial in your laptop - if you had it for more than that then you bought it. In that case the activation key must still be in your possession, just insert it when asked.
In the absolute worst case (the reinstall never finishes, no matter what you try) you will have to get a separate recovery disk from
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
and use it to reinstall.
Silverlight is an separate program that can be downloaded at any time by you from
http://www.microsoft.com/getsilverlight/Get-Started/Install/Default.aspx
Aug 21, 2011 | Acer Aspire M3641 Dual Core E2200 PC...
I was installing Windows 7 over Vista on an Acer Aspire 11.1 netbook with 2 Gig of ram. The system crashed (the chronic problem with Vista that I was trying to fix). Now I'm in a loop where Windows 7...
Have you tried to press F8 when the system boots ( initial screen ) and tried the safe mode or last known good configuration ?
If this does not help, try a recovery disk and it should work.
Regards,
Ron
Feb 11, 2011 | Acer Computer AO751h-1145 Aspire One 11.6"...
I have an Acer Aspire 5520-5334 how do i reset to factory settings? It is running window vista.
Acer PC or laptop
Step 1:
Click "Start" menu.
Step 2:
Click "Programs."
Step 3:
Click "Acer Recovery Management."
Step 4:
Click the "Restore" button on the bottom of the dialog box that opens.
Step 5:
Click "Restore System to Factory Default."
Step 6:
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Step 7:
Click "Start" to restore the computer to the default factory settings.
Tips & Warnings
If you are unable to access the Start menu, use the recovery CDs that came with the computer or visit Acer's website (see Resources below).
Always make a back-up CD before restoring a computer to factory defaults.
Resources
Feb 06, 2011 | Computers & Internet
Down loaded msn explorer 8 pc will not start up TMGR missing
The "TMGR" is a Windows Operating System component file.
This error might occur if the TMGR file is corrupted or missing.
However, as this is a Operating System Component file, you may resolve the issue by performing the below steps.
First, you may try performing the SFC Scan.
Performing the SFC Scan will automatically fix any damaged files or any errors in the Registry.
Steps to initiate the SFC Scan:
1) Open the RUN command window.
2) In the RUN command window, type "cmd" and press Enter.
3) In the Command prompt, type cd
4) Then. type cd Windows and press Enter.
5) Then type sfc /scannow and press Enter.
6) This will start the SFC Scan process.
The Computer might also ask for the Windows Operating System Disc.
Peforming the SFC Scan should resolve the issue with the TMGR file.
If the issue still persists, initiate the Disc checking process.
For Windows XP:
support.microsoft.com/kb/315265
For Windows Vista:
http://windows.microsoft.com/en-US/windows-vista/Check-your-hard-disk-for-errors
For Windows 7:
Jul 05, 2010 | Acer Aspire One PC Notebook
Presario desktop windows vista, shuts down unexpectedly
Windows Vista will not install on old computers. If this is your case try installing Windows XP, If this does not work you might want to try Linux (Ubuntu). which will run on almost any old computer with full capabilities.
It is free and you can download it from
http://www.ubuntu.com/
Feb 26, 2009 | Computers & Internet
Boot problem on Acer Extensa 4220
do a fresh installation of operating system or if your laptop provides recovery then you can also do that. may be your problem is due to system files.
Jun 28, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5500
Perform a system recovery:
Does not come with recovery cd's - there is a program that allows you to burn the disks or
recover.
3 ways:
1. If in Windows - Start - Programs - Acer empowering technology - Acer E-recovery management -
click on Restore at bottom then "Restore to factory default settings"
2. Or click on Burn disks instead of restore
3. if unable to ge into Windows then Alt/F10 during boot right after Acer splash screen on startup
End User Technical Support and Service (USA only)
For end user technical support, spare parts and service: 1.800.816.2237
Nov 06, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computer restor back to factory set
Pressing F10 on start up, is not for acer laptops, you need to have done a back up when you first got it running and use e-recovery to recover from your 'D' drive. see this explanation http://support.acer-euro.com/drivers/notebook/as_3680.html
Apr 19, 2007 | Acer Notebook
Acer Aspire 4520-5582 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
