Question about Maytag Neptune FAV6800AW Top Load Washer
Problems spinning I had my Maytag Neptune TL for 5 years and it won't spin properly what is thye problem?
  • 335 Answers
If it’s a FAV6800AW or FAV8900AW and you want to DIY a fix take a look at this post and see if you or someone you know has some very basic mechanical skills and can do a clutch replacement or roller clutch bearing re-lube. The dc/UC unbalance errors are a very common failure issue with the FAV6800AW/FAV9800AW clutch.
I have put together a step by step process to perform a clutch replacement process, this repair will get your $1000 machine back in service with a $50 dollar clutch replacement. Worse case you can give the repair person some facts and maybe control cost and speed to repair. I believe you will find you will pay $300 - $400 to have it repaired.
If you pay more than $50 dollars for the clutch you are throwing money away. Clothes Washer Clutch - 25001169
You can try this test just to rule out the TDS as the failure point almost all the time dc/UC unbalance errors are related to clutch issues with this machine model.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Press the Super Wash key display reads “in”…something like that.
Press Delicates the Display will show “UC” (Unbalance Closed).
Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
Press Hand Wash.
Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). If you get these results your Tub Displacement sensor should be OK and I believe it’s not the component failure producing dc/UC errors in spin cycle. I would remove the clutch for inspection and re-lube. There is a more technical troubleshooting method to check Tub Displacement Sensor in the Troubleshooting guide and Service manual.
We can turn on the drain pump in Service Mode to pump out excess water, let me know if you need help with that. The link I have in this post will send you to the Service Manual on this site in PDF format .
I believe a lot of folks toss this $1K machine when a $50 dollar clutch replacement or an even cheaper a Oneway roller clutch bearing clean up (if the bearings are rust free) will get the machine back in service.
Post back if you decide to DIY the fix and need help.
Good luck… Rich
Posted on Jul 29, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi - my maytag top loader FA5800AWW is stuck on wash cycle. it won't do the spin only and it is sometimes getting stuck locked.
I feel you have a Clutch issue Google this phrase ""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Repost on that site in the Maytag forum and I will help.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
0. We need a manual for Maytag Neptune TL. IT IS
f your machine is a FAV6800A or FAV9800A see if this post will help. Service manual link or located there. here it is just in case
Clutch Fix
Here it is just in case;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jun 25, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Very loud when spinning out.
IS THEE WASHING MACHINE LEVEL OR YOU MY NEED NEW DRUM BEARINGS
Feb 15, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAH5500B washer won' spin. LR appears on display.
maytag neptune washers do have a motor problem and they have a kit to replace the motor and motor controller.
when the motor fails, it wont wash or spin. most units have a 5 year parts warranty and should be replaced with a free part, but you will have to pay an authorized servicer to do this.
if it is over 5 years then i would call maytag and see if they will help you with an authorization for repair.
most of the time they will provide the part for free. just call the 800 # and ask for help. they wont send you the part but might give you some help with the parts.
Jan 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
377 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
