Question about Poulan Tools & Hardware - Others
Need manual for poulan model p3314 - Poulan Tools & Hardware - Others
rowdy45176
  • 2176 Answers
SOURCE: Poulan P3314 Automatic Oiler
Go to Poulanpro.com and look at a parts explosion and they also have a toll free number that might help. let me know if not and I will research more.
Posted on Feb 19, 2009
Editor925
  • 285 Answers
SOURCE: I just purchased a new model P3314 Poulan chain
PDF manual for the P3314 Chainsaw can be downloaded here
Posted on Mar 09, 2009
rowdy45176
  • 2176 Answers
SOURCE: need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
Posted on Mar 11, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Posted on Sep 04, 2009
dontbother10
  • 2220 Answers
SOURCE: Need the know the correct H and L settings for our
There are no hard and fast settings.
The initial starting point "H" and "L" are 1.5 turns CCW from lightly seated.
The"T" adjustment enters here too (idle speed) and there is initial setting without a tach, depending on age may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Fresh mix of fuel. Put ALL of the old mix in any 4 cycle and start new. I suggest 50:1 regardless of what your manual says. This is the best performance adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 10, 2010
HOW TO ADJUST THE CARB. ON A MODEL P3314 WILL START AND RUN FOR ABOUT 15 SECONDS AND THEN STOP RUNNING.
suspect that the diaphragm is going hard and is not sucking the fuel up from the tank properly
rekit the carby
Oct 02, 2016 | Poulan Garden
Where can I get a manual for a Poulan Pro 14" Gas Chainsaw 33CC P3314?
Sure! Click on "Get this Manual"
At:
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/p3314_p3314ws_p3314wsa_p3416_p3516pr_p4018wm_p4018wt_p3818av_p4018av_1.html
Sep 27, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan model p3314 recoil spring won't go in correctly
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Need chain saw fix
Mar 11, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Jan 10, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Tools & Hardware - Others Logo
141 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
