Question about Cycling
Over heating on water cooled qaudzilla 320e.Have checked water pump,heat sensor,water cooliant sensor, van, bleep system, checked hoses for leeks, straped out van so running all of the time . still over heats
  • 305 Answers
If its water cooled, then it will have a mechanical thermostat, which opens and closes to allow cooler water into the engine block, it will be located between radiator and block......the thermostat must be stuck in the closed position.....i advise changing the thermostat
Posted on Jul 28, 2009
My Van is over heating and I have no heat coming through the front or back vents?
This is the primary cause of engine overheating. Possible leak points include hoses, the radiator, water pump, thermostat housing, heater core, head gasket, freeze plugs, automatic transmission oil cooler, cylinder heads and block. ... A leak-free system should hold pressure for at least one minute.
Common Causes of Overheating ' ASC Industries, Inc.
asc-ind.com/cooling-system-information/common-causes-of-overheating/ Van is over heating Google Search
Dec 13, 2016 | Cars & Trucks
Coolant level on 2006 Toyota Avensis Tourer 2.2 T180, Very Low within two weeks of being topped up?
have a pressure test done on the cooling system and find the leak
it could be in the radiator tanks , timing cover behind the water pump, water pump seal, head gasket, cracked head or welsh plug rusted out
check the sump oil condition and if it is grey that is where the water is going
Nov 14, 2015 | 2006 Toyota Avensis 2.2
2005 gmc savanna van...cooling system will not blow hot heat. water pump,heater core,radaitor and thrmostate replaced. is there any electrical problems/
don't know this van specifically, but some things to check, make sure cabin filter is replaced or clean, you didn't say if the blower itself works, if not, correct or replace. Check the hoses going to the heater core, if hot water is flowing thru the core, both hoses should be hot. Check the heater controls to make sure doors in the system are opening closing as they should, you may just be drawing in cold air and not going thru the heater core.
Feb 11, 2015 | 2005 GMC Savana
My radiator hose popped off today iput it on and my car still over heats
You may have an air pocket with no fluid. This would cause over heating. If you have a recovery tank, it is better to add fluid thru there and not directly in radiator neck.
Sep 22, 2014 | 2001 Lincoln LS
No heat ,
Check the vacuum lines to make sure they are correctly connected and in good shape. If they are not, then the system wont move the dampers to allow hot air into the heat vents. A second possibility is a clogged heater core, which is not allowing hot water to circulate through it. As you say the head has been replaced, I would have someone insure every thing was reconnected correctly. It could be the hoses to the heater core are reversed!
Jan 18, 2013 | 2000 Ford Taurus
Green coolant leeking into cab 1984 rodeo ute
sounds like a bad heater core but check some older models had hoses that hooked to the core inside the car
Jun 16, 2012 | Cars & Trucks
2001 mercury villager over heating and no heat from heater have replaced thermostat ,radeator and cap water pump ,temp.sensor
Have your coolant system flushed then if the problem still exists then replace the heater core because it is clogged.
Jan 09, 2012 | Cars & Trucks
I have the 2001 GC ES with dual automatic climate control. The heat works in the front, but blows ice cold in the back, at all speeds, no matter how long vehicle has been moving. I'm starting to wonder if...
If you have heat in the front the engine cooling system is operating normally (waterpump ok) If the rear hoses were rusted out you would have front issues too due to collant loss. I sounds like either the rear controller has a problem with the temperature door actuator or an electrical problem going to the actuator. They sometimes have a heater valve which shuts off coolant flow to the rear heater core. It is located in the engine, where the rear hoses split to the rear. They are usually vacuum operated, possibly the valve or vacuum issue, check there. Feel the rear hoses under the van with the rear heat on. One should be hot and the other warm (this would indicate the heater core and valve are functioning). If the rear fan works the fuse is ok for the controller.
Jan 28, 2011 | 2001 Dodge Grand Caravan
NO HEAT
Your heating system is run by your cooling system. If your cooliant is low then you are not going to get adiquiate heat disapation to your heater core. So check the entire cooling systerm. Your water pump (low flow), hoses (leakage), you already checked the thermostat & heater core. So other than that I don't know.
Jan 15, 2009 | 1999 Chevrolet Silverado 1500
Cycling Logo
35 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
