Question about Car APS57A Remote Start and Keyless Entry System with Trunk Releas
Power mode issues
APS57A was professionally installed on my 2009 Chevy Silverado pickup with a 4.8L V8 engine & standard cab, 2WD. The problem is occasionally the remote start until will put the BCM (body control module) in what is called a backup mode. This is easily noticed by the radio and the lack of retained accessory power when ignition is shut off. This has accrued several times. The only way to return to normal operation is to pull the truck battery lead and reconnect. There is some incompatibility between this model and my truck. If it can't be resolved I will have to pull the module. If there is a model upgrade that may work better with my truck I would be willing to pay the additional cost. Please advice
    Scholar:
  • 55 Answers
Ask the installer if he is using the tach sensor wire for the remote start or is he using voltage? This could be where the condition you are describing occurs. Also AudioVox has beefed up it's dealer tech hotline so have your installer call them and see if there is a compatability issue. I wonder what bypass module he used? Was it an Express Kit or a DEI 555u? With the new CANBUS or LANBUS one has to be very careful when adding remote start. I believe its a somewhat simple fix. One more question? Can you DUPLICATE the problem for the shop or is it intermittant? That's a big help if a customer comes in and i can experience the sequence and see 1st hand what is happening at both the BCM & PCM because they have got to be in sync or there will be hell to pay. Let me know ... Mark@ Sounds Good to Me
Posted on Aug 15, 2009
I have a 2009 Chevy Silverado 1500 2wd pickup. The check engine light along with the service stabilitrak and traction control lights also came on. It runs rough at idle or low speed. Where do I start?
Have it check for DTC'S - diagnostic trouble codes . If the check engine light starts flashing , park it . The flashing check engine light is telling you there is a catalytic converter damaging miss fire happening . An they can be damaged very easy .
May 17, 2017 | Cars & Trucks
Reduce power is displayed and check engine light is on
run fault codes to find out what sensor activated the engine light. Check oil level and water level at the radiator cap. Something has failed for the light to come on and put the engine in limp home mode.
Nov 27, 2013 | 2012 Chevrolet Silverado 1500 Work Truck...
Change battery in 2012 silverado 2500
take positive and negative cables off of battery. now take battery hold down bolt out from back side of battery nearest to the cab. now lift battery out.
Nov 25, 2013 | 2012 Chevrolet Silverado 2500HD Work Truck...
2012 chevy silverado 1500 lug nut torque
Why so many different answers? I keep finding 140 ft/lbs.
Jan 07, 2013 | 2012 Chevrolet Silverado 1500 Work Truck...
Trouble Code 12 on 1993 chevy silverado
code 12 indicates that your in diagnostic mode
Nov 04, 2011 | 1993 Chevrolet C1500
How far back from the cab on a 2009 silverado short bed do i install hitch?
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 15, 2011 | Chevrolet 2500 Cars & Trucks
1998 Ford Truck F 150 2WD Pickup V8-4.6L SOHC VIN
this is not a job for the faint of heart!! you have to remove the complete dash! the heater box is located hehind the radio !in the middle of the dash ! theres no way around!!!
Mar 20, 2010 | 1998 Ford F150 Regular Cab
What engine do I have?
I'ts a chevy V8 350 engine. lol
Oct 04, 2009 | 1999 Chevrolet Silverado 1500
Where is the fuel filter?
I don't know about a 2wd,(mine is a 4 wd-extended cab) but, I just purchased an IN LINE FUEL filter from O'Reilly's Auto Parts. (02-01-2009 last night) The parts agent crawled under my truc and pointed out that the fuel filter was located uner the cab,attached to the drivers side frame,nearest to the back of the cab.
I might add, I had just checked with Advance Store Auto Parts, and the salesman there told me that there was not an external in line fuel filter,and I would have to get a complete fuel tank pump,filter screen assembly,from the chevrolet dealer.
I purchased a "WIX" in line filter and will put it on this p.m.
Hope this helps
Dec 17, 2008 | 2005 Chevrolet Silverado 1500 2WD
Car APS57A Remote Start and Keyless Entry System with Trunk Releas Logo
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
