Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Bracket control How to put back the bracket control the one on the dispenser front door?
  • Whirlpool Master
  • 1,606 Answers
Slip the top down in place , then lightly tap the bottom so the 2 plastic clips snap into place .
Posted on Aug 04, 2009
How to install samsung Part Number DC31-00054A (AP4202690)
1. Unplug the washer. 2. Unscrew the 2 screws at the top back of the washer that secures the top of washer pane, slide it back and lift off, remove and set aside. 3. Pull out the dispenser tray and depress the tab at the back to full remove. 4. Remove the dispenser mounting screws, slide the dispenser back. 5. Carefully pull the control panel off from the top, disconnect the two wire harnesses and set the control panel aside. 6. Use needle nose pliers to remove the retaining wire and spring from the door boot seal, pull the seal away from the lip of the front panel. 7. Remove the 3 door mounting screws to release door latch assembly from the front panel. 8. Open and detach the filter access door and release the drain tube from the retaining tab. 9. Remove the screws inside the filter housing securing the front panel. 10. Carefully lift the front of the washer up and support it. 11. You can now remove the screws at the bottom securing the front panel(if your has these, mine were missing). 12. Now is also a good time to detach the pump assembly wire retainer from the base(small white plastic tab sticking downward). 13. Remove the support and gently lower the washer back down. 14. Remove the mounting screws on top of the front panel. 15. Now, use a flat head screw driver to depress the locking tabs to release the front panel from the frame. 16. Detach the recirculation hose from the retaining brackets on the inside of the front panel and set the panel aside. 17. Uncap the drain tube, and drain the excess water, then recap the tube. 18. Release the retaining clamps securing the hoses to the pump assembly and slide the hoses off.(be prepared for some water to spill). 19. Remove the two screws securing the pump assembly to the mounting bracket. 20. Now, push the assembly back to release it from the base. 21. Next, detach the drain pump cover(top white plastic cover) and disconnect the wires, now remove the 3 mounting screws and pull off the old pump. 21. Install the new drain pump by properly aligning it on the assembly. 22. Replace the mounting screws to secure. 23. Connect the wires to the new pump and snap on the cover. 24. Position the pump assembly into the cabinet base by inserting the mounting tab into the slots in the base, then push forward. 25. Replace the screws to secure the assembly to the mounting bracket. 26. Snap the wire retainer into the base. 27. Reattach all of the hoses to the appropriate ports on the assembly and position the retaining clamps to secure. 28. Replace the front panel, by aligning the slots in the panel with the tabs on the base. 29. Secure the recirculation hose in the retaining brackets, making sure the door latch is inside the cabinet and snap the top half the panel into position. 30. Replace the screws on top. 31. Lift and support the washer, then replace the screws on bottom. 32. Remove the support and lower the washer. 33. Replace the 2 screws in the filter housing. 34. Secure the drain tube under the retaining tab. 35. Reattach the filter access door and snap it closed. 36. Now, realign the door latch assembly in the front panel, and replace the mounting screws. 37. Align the boot seal on the front lip of the panel. 38. Replace the retaining wire and spring to secure. 39. Replace the control panel, by first reconnecting the wire harnesses. 40. Now, insert the control panel tabs into the slots into the trim and snap the top half of the panel into place. 41. Reposition the dispenser and replace the mounting screws. 42. Slide the tray into place. 43. Reposition the top panel by aligning the edge of the panel with tabs on the support bracket, then push forward.
44. Replace the screws at the back. 45. Plug the power cord back in. Your done!
Your washer should be ready to use now!!! Good Job!
You should find this video useful, even if it is for a different model washer, it is what I used as a reference. Drain Pump Replacement part DC31 00054D Samsung Washer Repair
Sep 06, 2014 | Samsung WF448AAP Front Load Washer
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Replace bellow seal
Hello.
1 Unplug the power cord. Pull the Whirlpool Duet away from the wall. Remove the screws at the back of the machine using a Phillips screwdriver. Remove the top panel from the machine and set it aside.
2 Remove the soap dispenser from the front of the machine by pulling it out and depressing the button at the back to release it. Remove the soap dispenser bracket retaining screws, using a Phillips screwdriver. Pull the dispenser bracket out of the washer.
3 Remove the retaining screws from the control panel with a Phillips screwdriver. Release the locking clips and flip the control panel on top of the machine. There is no need to disconnect the wiring harness. Open the washing machine door and remove the retaining screws from the door latch, using a nut driver.
4 Remove the outer retaining spring from the bellow seal using a pair of needle-nose pliers to grasp the loop and pull it out. Peel the bellow away from the door opening, using your fingers. Push the bellow seal inside the machine after you release it from the door opening.
5 Lift the front of the washing machine and put a wooden block under it.
Remove the retaining screws from the bottom of the front panel using a nut driver. Remove the wooden block from under the washing machine and lower the unit back to the floor. Remove the screws at the top of the front panel with a nut driver. Pull the panel away from the machine and set it aside.
6 Pull the old bellow seal from the machine. Unplug the white and black hoses from the old bellow seal . Remove the spring clamp from the bellow and throw the old bellow seal away. Rub liquid laundry soap on the groove of the new bellow seal. Push the new bellow seal onto the washtub with the opening for the hoses at the top. Push firmly until it is on tight.
7 Install the spring clamp on the new bellow seal into the groove using a Phillips screwdriver. Plug the black and white hoses into the holes at the top of the bellow. Be careful not to damage the bellow seal. Place the front of the machine on the frame and install the top screws using a nut driver. Push the door latch through the hole and install the retaining screws.
8 Press the bellow seal into place around the door opening and install the spring clamp around the perimeter of the bellow. Lift the machine and place the wood block under it. Install the bottom screws with the nut driver. Remove the wooden block and place the machine back on the floor. Put the control panel in place and lock the retaining clips.
9 Install the soap dispenser bracket and the retaining screws using a Phillips screwdriver. Install the retaining screws on the control panel. Place the top cover on the machine and install the screws with the Phillips screwdriver. Plug in the power cord and push the machine against the wall. Install the soap dispenser drawer and push it all the way in so the tab locks into place.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
HOW DO YOU REPLACE THE DOOR LOCK I NEED TO KNOW HOW TO GET AT THE LOCK THE WASHER ONLY LOCKS IF YOU HOLD IN ON THE TOP OF THE DOOR
Disconnect power then open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. The top cover with the dispenser bezel off can be lifted to the rear of the machine to access the door locking mechanism, but you have to remove the front panel first.
Open the machine door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel then move it away and set it aside.
The top cover is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket.
Swing the bracket to the outside and unhook it from the slot in the top cover lip.
Open the door then lift the front of the top cover and tilt it toward the rear of the machine. The door locking mechanism can now be removed and replaced.. Reinstall the top cover and the front panel by following the removal steps in reverse order.
Jan 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do you change a pump on a Samsung WF448AAP washer? Need to get in from the back?
Dec 07, 2010 | Samsung WF448AAP Front Load Washer
Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge and the front panel to the front shroud assembly. Do the same to the two screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of the cabinet by grasping the upper part of the front panel posts and pressing in on the outer edges then twisting it inward. Once the front panel posts are released from the cabinet, tilt the front panel away from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
The fabric softner dispenser does not release the liquid softner
The fabric softener solenoid valve is faulty and must be replaced. It is sold as an assembly with the bleach solenoid valve with part number 997846. You need to remove the front panel to lift the top panel to inspect or replace the valves.
Front panel removal procedure:
  1. Unplug the machine.
  2. Turn off the water supply.
  3. Open the door and remove it by removing the screws on the hinges holding it.
  4. Remove the remaining two screws on the opposite side along the inside lip of the door opening.
  5. Press in on the outer upper edges of the front panel posts then twist it inward to release it from the clips on the face of the cabinet.
  6. Tilt the top of the front panel away from the washer and remove it.
  7. Remove the four screws holding the dispenser bezel to the top of the top panel.
  8. Remove the 5/16" hex head screws securing the two hold down brackets on the top panel.
  9. Swing the hold down brackets to the outside to unhook it from the slot in the top panel lip.
  10. Lift the front of the top panel and tilt it toward the rear of the machine.
  11. The dispenser valve assembly is the one on right of the water inlet valve assembly where the water supply line is attached to. The fabric softener dispenser valve is the one on the right most.
  12. Clean the terminals and the connector of the fabric softener dispenser valve.
  13. Grab a multimeter and check the resistance between its terminals. The resistance should be between 500 to 1000 ohms. If it reads open, replace the dispenser valve assembly.
  14. Remove the wire harness connections to the valve solenoids.
  15. Loosen and remove the hose clamps on the hoses.
  16. Loosen the valve mounting screws by turning it at least three full turns.
  17. Slide the valve assembly to the left and remove it from the bracket.
  18. Place a towel below the valve and remove the hoses.
  19. Install the new dispenser valve assembly in reverse order.
  20. Install the top panel, dispenser bezel, front panel and the door in reverse order of the removal procedure.
Jan 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Ice Dispenser not dispensing ice
Remove the top freezer door hinge cover and disconnect the plug there . This will remove power to the dispensor . Remove the dispensor grill , and also the 2 screws at the bottom of the dispensor front . Lift the front up and out , and remove the plug on the front . You should now see the white switch bracket . On the left side , is the ice dispensor motor switch , when usually , one of the spears holding the switch breaks off , not allowing the ice dispensor to work . If this is the case , the part number is 2180226 . Only held on by 2 screws . When/if replaceing , be sure to put the plastic spacers in the correct position next to both switches , and be careful not to break one of the spears , holding the switches .
Oct 31, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool side by side with an ice dispenser. The little door that closes on the outside opening of the ice dispenser has come loose from its bracket. I cannot get to it to reattach it, or even...
if it has become loose, the pin that holds the disp door came be put back into place. if the plastic tab that holds the pin into place broke, you will need to have a kit installed that has a metal bracket. that should be done by a tech. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
